budget CX tub build
Results 1 to 9 of 9
    Mar 2011
    budget CX tub build
    Considering a cheap CX tubular wheel build for the upcoming season. Thinking of the following
    Rims : Mavic Reflex
    Hubs : Shimano 5700 (105)
    Spokes: DT Comps
    32 holes, 3x cross
    This is roughly how the build should go (bit.ly/pwcMOU)... Is 49% a bit low for the DS/NSD ratio? How would I go about increasing this ratio for this hub/rim combo?
    Any comments on the build?
    Online Wheel Builder
    Reputation: Zen Cyclery's Avatar
    Mar 2009
    49% sounds a bit low on the NDS. I would suggest making sure that your wheel is dished perfectly. How heavy are you?
    Mar 2011
    I haven't build it yet, that 49% came from spoccalc. I'm 60-62kgs, pretty light...
    Do not touch the trim.
    Sep 2004
    There are about a gagillion wheels built out there with that flange spacing and basic rim/spoke combo with zero issues. Put the calculator away and get the wheels, they'll be fine.
    Mar 2011
    Quote Originally Posted by OnTheRivet View Post
    That's what I guessed
    Reputation: krisdrum's Avatar
    Oct 2007
    Not sure how that build prices out, but there are some pre-build options in the low $300 range you might also consider.
    Mar 2011
    I'm in Euroland but I couldn't find a whole lot of good deals. I can get pair of 5700 hubs for 55 + pair of rims for 80 and spokes for 32. Hard to do better than that
    Oct 2007
    Using 1.5 for Euro to Dollar conversion, I came up with: hubs (82.5), rims (120) and spokes (48) = $250.50, that is a pretty stellar deal. I was going to put forward the Grammo Tubulari CX, which retails for $299, but looks like you've got everything covered.
    Mar 2011
    If I could source them in the UK I'd go for it but from an initial Google, it doesn't look promising...
  1. Super budget build?
    By happa95 in forum General Cycling Discussion
    Last Post: 07-12-2011, 08:28 PM
  2. Budget Steel Build ?s
    By charlox5 in forum Bikes, Frames and Forks
    Last Post: 04-22-2011, 09:21 AM
  3. I want to build some light(er) wheels on a budget
    By MrTiles in forum Wheels and Tires
    Last Post: 07-17-2009, 12:28 PM
  4. Tarmac Pro SL build on a budget
    By ukbloke in forum Specialized
    Last Post: 01-12-2009, 03:53 PM
  5. new budget light build
    By moose8500 in forum Bikes, Frames and Forks
    Last Post: 10-04-2005, 07:36 PM
