Campy zondas with non-campy disc brakes?
Results 1 to 5 of 5
    Aug 2018
    I want to put Campy zondas on my bike. It has shimano components. I know I can swap out the cassette splines to accept non-campy cassettes, but what about the discs?
    'brifter' is a lame word.
    No problem, as long as you have center lock compatible wheels you're good to go. The Campy rotors are CL and come 140mm or 160mm. The mounting for those is standardized.
    I work for some bike racers
    and a bunch of skateboards
    Aug 2018
    What is a center lock?
    JSR
    JSR is online now
    Feb 2006
    Quote Originally Posted by coondogger View Post
    There are two standards for disc rotors: center lock and 6-bolt. This defines the interface between the rotor and hub. If you want to replace rotors the new ones need to be compatible with your hubs.
    It has small splines and a lockring to secure the rotor to the hub instead of the older 6 bolt standard.
  1. Disc brakes are awesome!!! / Disc brakes are Awesome???
    By metoou2 in forum Components, Wrenching
    Last Post: 01-18-2013, 04:28 PM
  2. Campy Zondas rear wheel out of true
    By bruin11 in forum Wheels and Tires
    Last Post: 12-10-2012, 11:37 AM
  3. Replies: 10
    Last Post: 08-13-2007, 11:41 AM
  4. Need some help... Just got some Campy Zondas...
    By bikerboy337 in forum Wheels and Tires
    Last Post: 05-26-2006, 09:47 AM
  5. Quick question on Campy Zondas.....
    Last Post: 04-30-2006, 03:17 PM
