Changing from 10 spr to 11 spd
Results 1 to 11 of 11
    Resident Curmudgeon
    Nov 2005
    Last summer my CF frame broke in a crash. I'm in the process of buying a new bike, but I'd like to use my existing wheels, which are 10 spd. The bike will be all Ultegra with rim brakes.
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    So what's your question?
    Feb 2002
    Quote Originally Posted by Mr. Versatile View Post
    Extrapolating from tlg's response, what you need to do is put an 11s cassette on your wheels instead of the 10s cassette you have now. A new set of cogs is all you need to do.
    tlg
    tlg is offline
    May 2011
    Not if his hubs aren't 11s compatible.
    Did you mean to specify a special conversion cassette like Lasco makes? Otherwise just slapping on a new cassette ain't going to work with the exception of certain Mavic hubs.
    tlg
    tlg is offline
    May 2011
    I'm pretty sure Mavic's (Shimano-compatible hubs) have always been 11sp compatible.
    Oct 2017
    My Father used to tell me 'If you want good answers, ask good questions...'.
    It's hard to tell exactly what you are looking for, but you'll need an 11 speed freehub on your wheel to support an 11 speed cassette. If the wheel is currently 10 speed, you are probably out of luck. If there is a 1.8mm spacer behind your 10 speed cassette, then an 11 speed cassette will probably work (without the spacer).
    yes, that is what I meant by Mavic being and exception.
    'brifter' is a lame word.
    This is one of the most un-answerable questions I've seen on here. It's not even a question. If it is...
    Yes.
    No.
    Maybe.
    Pick one...if you're actually asking a question.
    I work for some bike racers
    and a bunch of skateboards
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    Looks like he started a new thread:
    https://forums.roadbikereview.com/wh...ls-367637.html
    What the what???
    Jul 2009
    Yes.
    No.
    Maybe.
    To be fair, his name is Mr. Versatile... you have to expect a certain amount of ambiguity.
    The Law of Headwinds states: If the ride out is easy you better leave something in the tank for the turn...
  1. Changing from SPD to SPD-SL Cleats
    By Gary D in forum General Cycling Discussion
    Last Post: 03-27-2014, 06:01 AM
  2. Replies: 12
    Last Post: 08-13-2013, 06:17 AM
  3. Changing from Shimano spd sl road pedals to Look Keo's
    By jantar in forum Components, Wrenching
    Last Post: 05-21-2008, 04:25 PM
  4. "changing gear w/o changing the chain" chart?
    By Creakyknees in forum Fixed/Single Speed
    Last Post: 04-13-2008, 01:34 PM
  5. SPD vs SPR-R?
    By ddayton217 in forum General Cycling Discussion
    Last Post: 08-02-2004, 05:54 PM
