Changing speeds
Results 1 to 20 of 20
Thread: Changing speeds
    Resident Curmudgeon
    Nov 2005
    Changing speeds
    I apologize for the last thread I posted, in which I asked no question. It was late & I...well, you know.
    This is what it should have said:
    Last summer my CF frame broke in a crash. I'm in the process of buying a new bike, but I'd like to use my existing wheels, which are 10 spd. The bike will be all Ultegra with rim brakes. Do I need to have a new rear wheel built, or can I just put an 11spd cassette on the current Ultegra hub?
    Rub it............
    Reputation: frdfandc's Avatar
    Nov 2007
    What are your existing wheels?
    You can't fix stupid.
    Quote Originally Posted by JoeDaddio
    'brifter' is a lame word.
    You have yet to ask the question properly.
    I work for some bike racers
    and a bunch of skateboards
    ngl
    ngl is online now
    Jan 2002
    Quote Originally Posted by Mr. Versatile View Post
    If your new bike is all ultegra (including wheels) why would you want to replace new ultegra wheels with used ultegra wheels that were involved in a crash! This makes absolutely no sense.
    Quote Originally Posted by ngl View Post
    'All Ultegra' rarely includes wheels.
    Banned forever.....or not
    Aug 2002
    11 speed cassettes will usually not fit on a Shimano 10 speed hub. (unless you are able to machine the hub or the cassette, or buy a special cassette that already been machined) There is one exception. Shimano makes one cassette with a monster huge 34 or 36 (or larger) tooth cog, that is recessed enough to fit on a 10 speed hub. I'm sure that somebody here knows what cassette I'm talking about.....Otherwise, you'll have to buy a new 11 speed rear wheel. (of course, that might be obsolete next year if Shimano goes to 12 speed)
    Dogbert.
    I>U
    Resident Curmudgeon
    Nov 2005
    The wheels are fine & don't even need to be trued. The frame was broken.
    Resident Curmudgeon
    Nov 2005
    I thought I had. Everyone else seems to have grasped the meaning. I'll try again for you.
    I have a 10 spd rear wheel with an Ultegra hub. Can I put an 11 spd cassette on it, or do I need to have a new wheel built using an 11 speed Ultegra hub?
    Better?
    Aug 2002
    The only standard 11 speed cassette that would fit on your old wheel would be that large 34 tooth cogset.
    a non-standard can be found here https://www.lascoconcept.com/en/11s-cassette/
    Dogbert.
    I>U
    Better?
    Answered in post #9 8 hours ago and by me in post #10 4 hours ago. HG800 11-34 will work. Any other cassette will require new 11 speed hub.
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    So the 8000 11-speed cassette is compatible with 10-speed freehubs? I would be interested to know how this is possible. As usual, Shimano doesn't explain much on their website.
    Read again...HG800
    Banned Sock Puppet
    May 2014
    Read again...HG800
    OK, I see the cassette is the HG800 which belongs to the Ultegra 8000 set, no?
    My question remains, how is this possible?
    pmf
    pmf is offline
    Quote Originally Posted by MR_GRUMPY View Post
    And that stunt drove me to dumping Shimano in favor of Campy. Shimano didn't have to do that. They could have designed their 11-speed cassette to fit on a 10-speed wheel. Campy did. Shimano hubs were compatible with 8, 9 and 10 speed cassettes. So were they just hoping to sell more wheels?
    Stuff like this used to be referred to as 'non inline' product but they've included the HG800 cassettes in the Ultegra line. When they released the first road disc brake levers they were R6585/R785...not Ultegra or D/A. I don't have a good answer for why, but I'm guess because they got **** about 11 speed road not fitting on 10 speed freehubs. With the big cog being a 34 they have enough room to make it work now.
    Banned Sock Puppet
    May 2014
    Huh? How does a 34 cog make the cassette narrower? If an 11-speed cassette needs to measure a width of x and a 10-speed freehub measure a width of Y, how does a larger cog change that? Is the spacing on the 8000 cogs narrower than on the previous generation?
    No. Because the 34 is so big they can offset the spider that it's mounted on so it will clear the spokes. Won't work w/ a smaller cog. Take a look at the back of one someday, you'll see.
    Banned Sock Puppet
    May 2014
    Ahhhh, OK, got it!
    Aug 2002
    When Campy went to 9 speed, they changed the freehub design so that it wasn't compatible with 8 speed. Campy 9-10-11 speed freehubs are the same.....With Shimano, when they went to 9 speed, they stayed with the same freehub design, Shimano 8-9-10 speed freehubs are the same (except for early 10 speed)….Campy people were mad that they had to buy new wheels when 9 speed came out.
    Dogbert.
    I>U
  1. Replies: 12
    Last Post: 08-13-2013, 06:17 AM
  2. Replies: 6
    Last Post: 07-09-2013, 12:05 PM
  3. Can 10 speeds crank uses 11 speeds chain rings
    By slowoldman in forum Campagnolo
    Last Post: 05-28-2011, 08:17 AM
  4. "changing gear w/o changing the chain" chart?
    By Creakyknees in forum Fixed/Single Speed
    Last Post: 04-13-2008, 01:34 PM
  5. do 9 speeds shift better than 10 speeds?
    By pdxtim in forum Components, Wrenching
    Last Post: 10-18-2007, 09:57 PM
