Comfort vs. Speed in tire change
Results 1 to 25 of 31
    May 2020
    I am approaching 3,000 mi. on my 700x30 tires and contemplating going to 28mmís to pick up a little speed. I have a 2017 Specialized Diverge Sport that, when new, was set up for gravel with the 30mmís but I use mostly for road. I am 67 yrs. old I ride approx. 120 mi. a week. I Was going to upgrade my bike but am going to test different tires for a while before I do that. Any advice?
    Dec 2006
    Replace each tire as it wears. The rear will likely need replacement first. Rotate the front tire to the rear wheel, and buy a 28mm tire for the front. Switch from a wire beaded tire to a Kevlar/folding bead tire. Comfort is more a result of tire pressure, so experiment with lower tire pressures.
    JSR
    JSR is offline
    Feb 2006
    Iím thinking of going from 32 to 28 this summer. I think it will be plenty comfortable while saving a few grams.
    Having said that, I have a second pair of wheels shod with some hefty 32s. I figure those will be useful on rides including logging roads or light gravel.
    And then thereís the dream of getting a Salsa Warbird ...
    'brifter' is f'ing stupid
    Quote Originally Posted by jakeman View Post
    You won't go any faster by doing this. What pressure are you inflating the 30mm tires to and how much do you weigh?
    #promechaniclife
    What the what???
    Jul 2009
    In general, go with the widest tires your bike will accommodate inflated to the lowest pressure that doesn't cause pinch flats...
    Given his penchant for nicknames, and his aversion to reading, I've decided to shorten Donald J. Trump to it's essence: Dump*
    I was "social distancing" before it was cool.
    changingleaf
    Aug 2009
    The same tire 2mm narrower is not going to make a difference in speed. Tires that have heavy flat resistant barriers or low TPI can add a lot of rolling resistance. Like others have said you may want to lower the pressure and use a tire that is lighter and has lower rolling resistance. Not too low to cause rim hits, but lower pressure will be more comfortable, last longer and less likely to puncture when running over sharp objects.
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    Are you sure you have a Diverge Sport?
    Specs I looked up says it has these tires 28mm tires
    Specialized Espoir Sport, 60TPI, wire bead, double BlackBelt protection, 700x28mm
    Says the Diverge Comp has
    Roubaix Pro 2BR, 700x30/32mm, 2Bliss Ready, 120TPI, folding bead, BlackBelt, Endurant casing
    Going from 28's to 30's isn't going to pick up noticeable speed if at all. However, if you have 60tpi wire bead tires, going to a better tire with folding bead and higher thread count will be an improvement.
    op, it's not as simple as bigger = more comfortable and smaller = faster as a rule.
    TPI makes a big difference in comfort and even if that was the same between two different sized tires, which is faster would depend on your body weight and road conditions. (assuming optimum PSI in each).
    One will be faster than the other but when you are talking 2mm it won't be by enough to make any real difference.
    Then there's the issue of perception vs reality. A lot of people feel faster on 23ish tires with high PSI. But perception isn't always reality.
    Vittoria Corsa now makes a 30 mm tire. That might be a good one for you to look at to maintain, likely improve upon, the comfort you have and probably gain a little speed to. Their 28mm tires is also really good if you insist on trying 28.
    Not the best for longevity and flat protection but they are really good for speed and comfort.
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    As others here have already said, there are greater factors that impact speed and comfort than tire width. 2mm difference will not make a noticeable difference in speed regardless.
    A more supple tire will be both faster and more comfortable at the expense of sidewall cuts. That being said, if your riding is primarily on paved roads, sidewall cuts are very rare - most punctures will be in the tread surface. Supple high thread count tires are also more expensive. Rene Herse makes some excellent tires which are super comfy and roll really nice, but they are expensive:
    https://www.renehersecycles.com/shop...-chinook-pass/
    Also, don't be fooled my some tire companies' claims of TPI. A few tire makers advertise their tires as over 300 TPI which are really 3 layers of 100. 120 is definitely more supple than 60 which is definitely more supple than 30. Any claim of more than 120 TPI is poppycock.
    "If someone needs 200 rolls of toilet paper for a 14-day quarantine, they probably should have made a doctor's appointment way before the COVID-19 outbreak." -- Unknown
    "With
    -- DCGriz, RBR.
    That's not true.
    https://forums.roadbikereview.com/wh...pi-357058.html
    Banned Sock Puppet
    May 2014
    Precisely my point in your own words here:
    In other words it's Conti's way of trying to fool people that they use 330 when it's actually 110.
    "With
    -- DCGriz, RBR.
    No that wasn't your point.
    "Any claim of more than 120 TPI is poppycock."
    Continental's claim is not any claim it's their claim. Some companies claim higher than 120 and it's for a single layer of casing thus not poppycock.
    May 2020
    Thank you. I agree with the consensus of responders...going 2mm down will not give me much speed. The tires I currently have are Espoir Sport 700x30 60 TPI with a recommendEd 85-95 psi. I am testing at 70 psi now and will await results...thank again
    May 2020
    Thank you Jay. Iíll research the. Vittoria. Longevity not as much of a concern as flat protection.
    May 2020
    Thank you Lombard for your advice. I have some research to do but I think Iíll be staying with the 30mm tires based on the responses. I have been happy with my current Espoir Sport tire for 3000 miles. Itís a 60 TPI wire bead but based on your response I have some work to do.
    May 2020
    Currently riding Espoir Sport 60 TPI....recommended psi 85-95. I am satisfied with the 3000 mi. I put on them....think Iíll stick with the 30mm and research TPI
    May 2020
    Yes it is. I couldnít copy/paste photo of the tire but it is a Espoir Sport 700x30mm...85-95 psi and 60TPI
    May 2020
    Cxwrench. Thanks for reply.
    Recommended Psi for the Espoir Sport is 85-95. I have been using bet. 70-75 psi. I am 6í4Ē 210 lbs.....hey Iím trying!
    Banned Sock Puppet
    May 2014
    Can you name one?
    "With
    -- DCGriz, RBR.
    Banned Sock Puppet
    May 2014
    Rene Herse doesn't make a 30mm tire, so I linked the 28mm Chinook Pass. They also make a 32mm tire, but not sure if that one will fit in your bike.
    You will probably notice a difference going from a 60 TPI wire bead tire to a 120 TPI aramid bead tire.
    "With
    -- DCGriz, RBR.
    May 2020
    Thanks again Lombard.
    May 2020
    Thanks changinleaf...think Iíll stick with the 30ís and research TPI
    tlg
    tlg is offline
    May 2011
    Who recommended 85-95?
    Keep using 70-75. That's about right for your weight. 70 may be on the low side, but if you're not getting pinch flats, and you like the ride, keep using it. It's going to give you the best ride. 70 in the front and 75 in the back is probably perfect.
    If you drop weight, you can drop the pressure.
    Can you name one?
    Vittoria, Veloflex, Challenge.
    Longevity and flat protection pretty much go hand in hand. The ones I mentioned, Vittoria Corsa Control 30mm, are beefed up a bit more than a typical super light race tire so they are not 'bad' in that regard but you can do better if flat protection is your top priority.
    Keep in mind you can't really have your cake and eat it too. Generally speaking the more you go for flat protection the less you get for speed and comfort.
  1. Replies: 7
    Last Post: 05-05-2015, 10:51 AM
  2. Chain Durability: 8-speed vs 9-speed vs 10-speed
    By SystemShock in forum Components, Wrenching
    Last Post: 08-07-2008, 04:57 AM
  3. Comfort vs. Speed... Newbie confused...
    By centaur999 in forum Bikes, Frames and Forks
    Last Post: 10-21-2007, 03:35 PM
  4. Comfort vs speed
    By dan0 in forum General Cycling Discussion
    Last Post: 06-27-2007, 09:36 AM
  5. Poal: Change name, change profession, change both?
    By mickey-mac in forum The Lounge
    Last Post: 06-11-2007, 12:07 PM
