• 08-13-2019
    steinercat
    Conti GP 4 Seasons 28c vs 32c
    Iíll be going on my 3rd set of GP4ís (28c). For the type of riding I do, and my priority (puncture resistance), these are ideal tires.
    My frame can accommodate 32c tires, and I was toying with the idea of going 32c when I change tires.
    Anyone who has related experience care to chime in? Iím not too concerned about weight. But am tempted to try for added comfort and *better* protection against pinch flats.
  • 08-13-2019
    cxwrench
    28mm v 32mm.
    Generally you would lower the pressure 10ish psi going from 28mm tires to 32mm to maintain the same surface tension or feel. But...because you have more air volume in the 32mm tire you can actually drop down more. The additional volume will protect the rim a little better so you can go lower and get a better ride, and better traction. In my case I'd inflate 28mm tires to around 70. For the same 'feel' with a 32mm tire I'd inflate to around 60, but I would personally go to low-mid 50s.
  • 08-14-2019
    Srode
    Quote:
    might want to add your weight for better perspective.
  • 08-14-2019
    Jay Strongbow
    Tires wear out. Regardless of that you think of them there really isn't much risk in doing the only thing you can do to see what you think and that is trying them.
    You might not be impressed but there is about 0% chance you'd decide an extra 4mm will make the unusable.
  • 08-14-2019
    harryman
    If you like 28s, you'll probably like 32s even more. At it's worse, it's just a short term experiment.
  • 08-14-2019
    Kerry Irons
    The wider tires at lower pressures will also wear longer and give you better traction. They might be difficult to remove from the bike because of the width getting past the brake pads.
  • 08-14-2019
    bvber
    Quote:
    Not if it's deflated. :cool:
  • 08-14-2019
    steinercat
    Not an issue for me, with disc brakes.
    Will give the 32c a go then.
    Thanks all! [emoji106]
  • 08-14-2019
    cxwrench
    Quote:
    Good point, I forgot to do that. I'm just at or slightly below 170.
    Wonder if the OP got my subtle hint about not using 'C' and using the proper 'mm'?
