Conti GP 4 Seasons 28c vs 32c
Results 1 to 9 of 9
    Apr 2015
    I値l be going on my 3rd set of GP4痴 (28c). For the type of riding I do, and my priority (puncture resistance), these are ideal tires.
    My frame can accommodate 32c tires, and I was toying with the idea of going 32c when I change tires.
    Anyone who has related experience care to chime in? I知 not too concerned about weight. But am tempted to try for added comfort and *better* protection against pinch flats.
    'brifter' is f'ing stupid
    28mm v 32mm.
    Generally you would lower the pressure 10ish psi going from 28mm tires to 32mm to maintain the same surface tension or feel. But...because you have more air volume in the 32mm tire you can actually drop down more. The additional volume will protect the rim a little better so you can go lower and get a better ride, and better traction. In my case I'd inflate 28mm tires to around 70. For the same 'feel' with a 32mm tire I'd inflate to around 60, but I would personally go to low-mid 50s.
    #promechaniclife
    Reputation: Srode's Avatar
    Aug 2012
    might want to add your weight for better perspective.
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Niner RLT9 RDO
    BH G7 Disc
    Trek Crockett
    Tires wear out. Regardless of that you think of them there really isn't much risk in doing the only thing you can do to see what you think and that is trying them.
    You might not be impressed but there is about 0% chance you'd decide an extra 4mm will make the unusable.
    Nov 2014
    If you like 28s, you'll probably like 32s even more. At it's worse, it's just a short term experiment.
    Feb 2002
    Quote Originally Posted by steinercat View Post
    The wider tires at lower pressures will also wear longer and give you better traction. They might be difficult to remove from the bike because of the width getting past the brake pads.
    Apr 2011
    Not if it's deflated.
    Apr 2015
    Not an issue for me, with disc brakes.
    Will give the 32c a go then.
    Thanks all!
    Good point, I forgot to do that. I'm just at or slightly below 170.
    Wonder if the OP got my subtle hint about not using 'C' and using the proper 'mm'?
    #promechaniclife
  1. Replies: 2
    Last Post: 08-07-2010, 08:45 AM
  2. Continental GP 4-seasons vs other conti tires
    By paul2432 in forum Wheels and Tires
    Last Post: 12-29-2009, 07:36 PM
  3. Continental GP 4-Seasons IN 28MM?
    By KeatonR in forum Wheels and Tires
    Last Post: 12-25-2008, 11:16 PM
  4. Conti 4 seasons 28c...slow?
    By FlatlandRoller in forum Wheels and Tires
    Last Post: 08-10-2006, 04:27 PM
  5. Conti GP 4 seasons
    By roadboy in forum Wheels and Tires
    Last Post: 12-14-2005, 08:21 PM
