Conti GP5000 28 actual width on 21C and 25C rims
Results 1 to 6 of 6
    May 2019
    Anyone out here measured actual width of Continental Gp5000 700x28C tires on 21C or 25C rims, around 80 psi?
    Feb 2002
    Quote Originally Posted by igs532 View Post
    You have to be more specific about the rim because not all "21 mm" rims are the same width. And even if you are more specific, new tires will measure differently than tires with miles on them. And then you have to hope that somebody has the same rims and tires mounted as you request.
    'brifter' is a lame word.
    "mm" not "C". All modern road rims are 700 "C" and everyone knows this. Tires for these wheels should be referred to as 700 x XXmm, not 700 x XXC. The width of the rim should also be referred to in mm, and for tire width questions you should use the internal rim measurement.
    I work for some bike racers
    and a bunch of skateboards
    Reputation: velodog's Avatar
    Sep 2007
    ^^^^This^^^^
    It drives me nuts to see tire sizes referred to as XXc and not mm, and I could walk there.
    And now rim width. AARGH .
    Too old to ride plastic
    ^^^^This^^^^
    It doesn't help that so many tire companies have no clue. Rim sizes are described as 650A, 650B, 650C, 700B, 700C. Tire sizes are obviously the same, but must include the width. If you're going to label a tire properly it should be '700C 25mm'. 700 x 25C is just dumb.
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    Don't know why tires are labeled this way 700 x 25c when they should be labeled 700c x 25. Not to mention that 700c is used when the actual rim diameter is 622mm. 700c = 29 = 622mm and 650b = 27.5 = 584mm. More confusing than car tire sizes.
    igs532,
    In order to help you clear the confusion, Sheldon Brown explains it well here. After reading this page below, you will either have a clearer understanding of tire sizes or your head will be spinning even more:
    https://www.sheldonbrown.com/tire-sizing.html
    And yes, another thing that drives me nuts is rim manufacturers that use the external width measurement. External rim measurement is totally useless. INTERNAL rim measurement is the one that will affect the actual width of your tires once mounted. I don't give a rats arse what the external rim width is.
  1. Replies: 0
    Last Post: 07-18-2017, 02:10 PM
  2. Actual photo, actual product
    By Mel Erickson in forum The Lounge
    Last Post: 07-17-2011, 02:15 PM
  3. Replies: 89
    Last Post: 04-09-2011, 03:29 PM
  4. 3T Funda Pro and Conti GP4000 25c clearance
    By j.king in forum Wheels and Tires
    Last Post: 01-18-2011, 11:18 AM
  5. Gotta set of 700 x 21c tires will my tubes fit?
    By Erotomaniac in forum Wheels and Tires
    Last Post: 11-07-2005, 11:20 PM
