Enve Cutting Tires...
Results 1 to 16 of 16
    Cleavage Of The Tetons
    Reputation: rideit's Avatar
    Feb 2005
    And the tire companies are calling BS
    https://www.bicycleretailer.com/prod...g#.XJAauRpMGhB
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    I have read about the Challenge hand-made "open tubular" tires having problems before this.
    There is no question this type of tire is more fragile than standard vulcanized tires. If nothing else, definitely more prone to punctures. I guess that is the trade-off if you want that plush, soft as a pillow Lincoln Town Car ride.
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    Quote Originally Posted by rideit View Post
    It seems evident that the tire companies haven't actually read ENVE's statement.
    ENVE never said "its their tires"...rather it is the combination of tire and rim that don't work well.
    I have about 60,000 miles on cotton open tubulars from Vit or Challenge (mostly Vit) and I'm calling BS too. Counting guys I ride with who use the same tires and have not had these types of problems either we are talking hundreds of thousands of miles problem free.
    Anecdotal sure but....................
    Feb 2002
    Are they riding with these rims? The argument is that the rim has a sharp edge and that this type of tires has a harder time resisting the cutting from the sharp edge. It can be a long debate about "not a problem for most tires, so it must be the tires" vs. "not a problem for these tires on most rims, so it must be the rims."
    Banned Sock Puppet
    May 2014
    Why am a reminded of the finger pointing contest that Ford and Firestone had awhile back? Ford said Firestone Wilderness AT tires had tread separation issues and Firestone shot back it was because Ford recommended pressures too low on their Explorer SUV.
    No, I don't know anyone who has those rims.
    I get what you are saying about potential long debates but IMO when you consider the tires has been on the market for a long time, are very common, and haven't had the problems with other rims I don't think it's a very long debate.
    Cotton open tubular tires (Vit, VeloFlex, and Challange) are extremely common, especially in the target market Enve is shooting at, so if you are going to introduce a product to the market it should either work with what everyone and their brother is using or disclose that it won't before learning the hard way.
    I can't think of a good analogy but it's kind of like introducing crank that Look and Shimano pedals will fall out of. Regardless of if it's a combination of crank and pedal I'd fault the crank maker for not making it compatible with that they know tons of people use and not disclosing that before learning the hard way.
    Sep 2011
    and what's the design purpose of making sharp edges?
    And what if we were to sand down the edges a bit to make them a tad more blunt? wouldn't this be a good idea anway?
    Jan 2005
    You'd be willing to take sandpaper to a set of CF wheels that cost as much as a used car? I applaud your bravery.
    Sep 2011
    I've sanded down the Zipp 404 Firecrest clinchers when I had those. These rims don't have sharp edge, but my particular rear rim kept causing random slow leak by puncturing a very tiny hole to the inner tube. So after a few tube changes it left me scratching my head as to why my innter tube kept flatting with a slow leak. Finally I took very fine sandpaper and lapped up the bead hook a bit, nothing major, but enough to end the mystery slow leak! I bought these wheels used so going to Zipp wasn't an option.
    But back to my previous question. Why did Enve need to make the edge sharper than other rim manufacturers? and couldn't we just smooth up the edge by lightly sanding it? Well if were to use my Zipp experience, and I bought used Enve wheels, then I'd take the chance to sand the Enve lightly.
    I didn't read very closely but I didn't get the impression sharpness is actually the problem. I think it's the design. Angle, placement, whatever. Cuts are half the warning. Also part of it is tires blowing off the rim.
    Nov 2002
    It's the tight edge radius (smaller than the ETRTO standard). Read the blurb by Challenge on their website.
    I just read it. That makes it pretty clear and more or less what I was speculating with the issue.
    Reputation: Srode's Avatar
    Aug 2012
    I would just use different tires before I sanded the wheels on an expensive carbon wheel set to break the edge.
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    BH G7 Disc
    Trek Crockett
    May 2012
    Looks like Enve may have some recent QC problems.
    https://www.pinkbike.com/news/review...-wheelset.html
    Sep 2011
    Lightbulb
    Quote Originally Posted by Bremerradkurier View Post
    from the article, here's a quote from Enve's VP Product:
    Quote Originally Posted by Jake Pantone, VP Product and Consumer Experience
    There is this idea that if a product is damaged or breaks within a certain distance, it is worse than a product that breaks or wears out eventually. Carbon doesn’t fatigue...
    ugh, carbon does fatigue. How about that, a VP who doesn't know his stuff.
  1. Enve M50 or Enve 4.5 AR
    By transientgolf in forum Cyclocross
    Last Post: 11-13-2016, 10:57 AM
  2. Enve 2.2 with CKr45c versus Enve 2.2 with DTS 240s hubs
    By Cni2i in forum Wheels and Tires
    Last Post: 10-24-2016, 03:56 PM
  3. Replies: 9
    Last Post: 08-21-2014, 01:01 PM
  4. Mad Fiber, ENVE 6.7, or ENVE 3.4?
    By skappy7 in forum Wheels and Tires
    Last Post: 06-11-2013, 07:18 AM
  5. Keep cutting tires ???
    By mudphalt in forum Components, Wrenching
    Last Post: 07-12-2009, 02:38 PM
