• 05-07-2019
    SPlKE
    Quote:
    Originally Posted by Lombard View Post
    You don't need wider tires, the Prolink you use gives you that smoother wider-tire ride. :thumbsup:
    ... goes without saying.
  • 05-07-2019
    Bremerradkurier
    Quote:
    Originally Posted by SPlKE View Post
    I wish I could join the wide tire revolution.
    Unfortunately, my 1997 LeMond Alpe d'Huez frame and fork are stuck in the 23 era.
    The frame geometry is so incredibly freakin perfect for me... and I have it dialed in so perfectly with all the NOS campy record and chorus components I've added over the years, I can't imagine buying a new bike to run wider tires. I did add Easton CF bars, which helps a lot with the 23-hard-tire vibration. But I'd love to be running some wider, lower pressure tires.
    Got my teenage son a low mileage shark fin Trek Madone on a screaming deal on Craigslist-23 or 25c tires on 17mm inner rims wouldn't fit but even 25c tires do mounted on 19mm i.w. rims-see if you can borrow some wider rimmed wheels
  • 05-07-2019
    SPlKE
    Quote:
    I don't think I can find 19 mm rims to borrow that will accommodate my campy 8-speed cassette.
  • 05-07-2019
    Bremerradkurier
    You'd be stuck on one gear for test riding after checking for frame clearance-assuming they fit, you could then lace up wider rims on your current hubs; many of them still come in 32 hole versions.
