finally joined the 'wider' tire movement... - Page 2
Page 2 of 2 FirstFirst 12
Results 26 to 29 of 29
  1. #26
    Schuylkill Trail Bum
    Reputation: SPlKE's Avatar
    Sep 2007
    You don't need wider tires, the Prolink you use gives you that smoother wider-tire ride.
    ... goes without saying.
  2. #27
    May 2012
    Quote Originally Posted by SPlKE View Post
    I wish I could join the wide tire revolution.
    Unfortunately, my 1997 LeMond Alpe d'Huez frame and fork are stuck in the 23 era.
    The frame geometry is so incredibly freakin perfect for me... and I have it dialed in so perfectly with all the NOS campy record and chorus components I've added over the years, I can't imagine buying a new bike to run wider tires. I did add Easton CF bars, which helps a lot with the 23-hard-tire vibration. But I'd love to be running some wider, lower pressure tires.
    Got my teenage son a low mileage shark fin Trek Madone on a screaming deal on Craigslist-23 or 25c tires on 17mm inner rims wouldn't fit but even 25c tires do mounted on 19mm i.w. rims-see if you can borrow some wider rimmed wheels
  3. #28
    Sep 2007
    Quote Originally Posted by Bremerradkurier View Post
    I don't think I can find 19 mm rims to borrow that will accommodate my campy 8-speed cassette.
  4. #29
    May 2012
    You'd be stuck on one gear for test riding after checking for frame clearance-assuming they fit, you could then lace up wider rims on your current hubs; many of them still come in 32 hole versions.
  1. Wider rims, Wider tires... Wider inner tubes?
    By ToffieBoi in forum Fixed/Single Speed
    Last Post: 08-18-2013, 11:54 AM
  2. Finally joined the darkside and got my first road bike.
    By d1zzl3 in forum Beginner's Corner
    Last Post: 09-03-2012, 05:06 AM
  3. wider tire, lower rolling resistance?
    By orbeamike in forum Components, Wrenching
    Last Post: 06-10-2009, 07:47 AM
  4. Does wider tire width reduce flats?
    By holdenJames in forum Wheels and Tires
    Last Post: 12-21-2007, 11:56 PM
  5. Finally joined the ranks...
    By MellowDramatic in forum Fixed/Single Speed
    Last Post: 10-02-2007, 11:03 AM
