Giant SLR1 carbon wheelset - is this a problem?
Results 1 to 8 of 8
    Aug 2006
    I really love my Giant SLR1 carbon wheelset but the front wheel has developed a series of strange lines on the spoke side. They go almost all the way around but never open up into cracks or gaps. No they are not scratches (note they go under the sticker).
    Never been crashed, no extreme temps, no off road, etc.. just regular road use. Vittoria Rubino Pro clinchers 700x23, ~115 psi (lower than recommended max). I'm 158 lbs.
    No response from Giant by email (3 days).
    Could it just be an issue with clearcoat or something (?)?
    IMG_3450.jpg.
    Oct 2013
    I would take them back..... Those cracks could explode at any minute, or not!
    BANNED
    'brifter' is f'ing stupid
    115psi?!? I don't even know what size they are and that's too much.
    If you've got that much pressure in them and they're still in one piece they're probably fine. Just so we know...what size tires?
    ETA: I'm an idiot, the size is right there in your post. But that's still wayyyyyyy to much pressure.
    #promechaniclife
    Feb 2002
    Quote Originally Posted by bchains View Post
    You should be running 90 F, 100 R MAX at your weight and that tire width.
    Aug 2006
    To close the loop on this... I went to my LBC and the mechanic said he has seen this before with Giant SLR1 wheels. Even showed me another wheel in the shop that had it. Then with me there he called the Giant rep/warranty person and described the problem and emailed them pics of my rims in real time. Giant said they had also seen this before and its "the way the carbon layup settles in over time." Apparently its the edges of a few of the layers are now just becoming more apparent (somehow??!). They said the wheels are totally safe to continue to ride even downhill at high speed.
    I don't know enough about carbon layup and wheel construction to dispute this, and because there isn't any sort of crack or anything I can feel with my fingers I'm going to believe what they are telling me.
    Will report back if anything more happens.
    Please tell me you've lowered the pressure some. I'd definitely recommend 25mm tires as well.
    #promechaniclife
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    OMG!!! 115 PSI at 158 lbs.????? At your weight, I would be running 80 PSI front/100 PSI rear with those tires unless you are carrying a 20+ lb. bag on your bike.
    "With
    -- DCGriz, RBR.
    Never Give Up!
    Mar 2009
    That looks wicked scary to me, but I'm not wheel expert.
    I agree about the tire pressure your running... I'm 5.6 weigh 132 and run my Panaracer RACE evo 700/25c at 65psi Front and 80psi Rear with no issues
    2010 Orbea Onix w/Ultegra R8000
    2007 IRONHORSE HT
  1. Can I install Di2 on Giant TCX SLR1?
    By manamana in forum Components, Wrenching
    Last Post: 02-27-2017, 11:04 AM
  2. Mavic R-SYS or Giant P-SLR1
    By TJay74 in forum Wheels and Tires
    Last Post: 03-27-2014, 10:58 AM
  3. Anybody ridden the new Giant P-SLR1 Aero wheels...Thoughts?
    By rs_herhuth in forum General Cycling Discussion
    Last Post: 09-16-2013, 03:27 PM
  4. Replies: 0
    Last Post: 11-03-2011, 12:21 PM
