Good 700c tire around 40 mm for wet roads?
Results 1 to 11 of 11
    Jun 2020
    I'm looking for new 700c tires in the 37 to 42 (maybe up to 45) mm range for road use on my wife's cruiser bike. The most important feature would be sticky rubber for wet traction in cool weather (Pacific Northwest). I don't care if they wear faster due to a softer compound or if they're a bit more expensive. Folding or wire bead is OK.
    Tread pattern is mostly irrelevant since these would be used only on pavement unless she is forced off the bikeway into the grass due to (dog/babystroller/Jumpbike/solowheel) traffic, but a bit of tread might be visually reassuring.
    A reflective stripe would also be a plus, but not required. The Conti Contact Plus look cool, but more tread than is really needed.
    Suggestions?
    Donnelly X'Plor tires are really nice as far as that size range goes.
    Reputation: velodog's Avatar
    Sep 2007
    Too old to ride plastic
    'brifter' is f'ing stupid
    ^This^. I have the 44mm Snoqualamie Pass...they're exactly 40mm on every rim I've put them on.
    #promechaniclife
    Jun 2020
    This is all making me want to put wider tires on my retro-direct. The chain tends to drop off one or both freewheels when I hit a bump. I have 25 mm tires on it now. Going up to around 40 mm and lower pressure might help quite a bit.
    Nov 2014
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    I will agree the Rene Herse tires are really nice. I was a bit hesitant at first, but got the ultra-light version and man, are they ever comfy and fast on my gravel bike! Pricey though.
    "With
    -- DCGriz, RBR.
    Jun 2020
    Crud. The chainstays on my retro-direct look like they have room for 38 mm tires, but the brake calipers *might* allow 32s.
    Sep 2007
    Quote Originally Posted by BuckRimfire View Post
    https://www.renehersecycles.com/shop...stampede-pass/
    These measure 30mm on my wives bike.
    Jun 2020
    How high above the rim? The limiting point will be where the mounting bolt goes through the caliper, so centered right over the wheel.
    Sep 2007
    About the same 30mm. Probably give or take a mm.
  1. Attack/Force? Smaller mm F & Larger mm R tire?
    By DonDenver in forum Wheels and Tires
    Last Post: 03-22-2011, 04:01 PM
  2. Foldable Tire in 40 or 42 mm
    By elmar schrauth in forum Cyclocross
    Last Post: 10-22-2008, 07:13 PM
  3. How does the Mondo S-Works tire work on wet roads?
    By Clark in forum Wheels and Tires
    Last Post: 04-27-2006, 12:37 PM
  4. 130 mm hub on 135 mm aluminum frame OK?
    By NoMSG in forum Components, Wrenching
    Last Post: 10-16-2005, 10:12 PM
  5. 43 mm vs. 45 mm rake
    Last Post: 11-23-2004, 08:34 AM
