Got screwed ...
Results 1 to 7 of 7
Thread: Got screwed ...
    Feb 2020
    Got screwed ...
    OK, about 800 miles into the Great Tubeless Experiment and ... I believe!
    Somehow I picked up a screw and rather than pull it out and make a mess I decided to ride it the remaining 8-9 miles home. Of course I didn't have a plug kit (though I did have an inner tube) but even the next day it was holding pressure.
    So how do I fix this? Are the anchovies from a plug kit a permanent fix? Is this going to require a proper plug of tire material (whatever that is) and RTV/rubber/glue? How does a screw embed itself like this anyway?
    Oct 2013
    If you have the cash, the easy way is to get a new tire.
    If you don't, go to an auto parts store and get a thing called a tire boot, it's a patch that has cords in it. Get the smallest/thinnest one you can, cut it down to fit from bead to bead -1/2", take a drill with wire brush and wire brush the whole area (on the inside of course), put on rubber cement if required & apply patch.
    I would not ride that tire on the front, nor over 20mph.
    BANNED
    Reputation: Srode's Avatar
    Aug 2012
    Sure plugs last if they are put in right. Plug it and run it if it holds air.
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Niner RLT9 RDO
    BH G7 Disc
    Trek Crockett
    Russian Troll Farmer
    Sep 2016
    I'd do that, and add a vulcanizing step afterwards; hit it up with a propane pencil torch, then clamp it to make it adhere. A vulcanized patch will never come off.
    "L'enfer, c'est les autres"
    Feb 2020
    Didn't think about an auto parts store ... think I'll try that. Thanks, all!
    Oct 2013
    Yea, don't use a plug, that's just to hold air.
    BANNED
    Feb 2002
    Might be a challenge getting the sealant off the tire surface to get a good bond with the boot. Make sure things are super clean before gluing the boot.
  1. i think i got screwed....
    By jrb985 in forum Components, Wrenching
    Last Post: 06-13-2006, 08:51 AM
  2. Vino just got screwed...
    By Truth Hurts in forum The Doping Forum
    Last Post: 05-25-2006, 05:41 PM
  3. Vino just got screwed...
    By Truth Hurts in forum Pro Cycling - Tour de France
    Last Post: 05-25-2006, 06:32 AM
  4. Race Report.........I got "Screwed"
    By MR_GRUMPY in forum Racing, Training, Nutrition, Triathlons
    Last Post: 05-15-2006, 10:45 PM
  5. mcewen got screwed
    By bas in forum Pro Cycling - Tour de France
    Last Post: 07-06-2005, 05:08 AM
