GP 5000 vs Schwalbe Pro One TL comparison - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 51
  1. #26
    Sep 2010
    1200 mile update
    After about 1200 miles on the GP5000 TL's, much of it in the rain, it seems they are far more puncture resistant than the Schwalbe Pro One's. I would always have cuts in the tread of the Schwalbes by the time I took them off. No cuts in the GP5000's. That's weird given how much riding in crap road conditions I did in January. Had two slow punctures on the GP5000 TL that sealed themselves quickly, only one of which required I stop and top off the tire with the mini pump. The other only lost maybe 20psi then sealed for good so I never stopped.
    Not scientific but based on long history with the Schwalbe Pro One TL and a solid rainy month on the GP5000 TL, my opinion is the the GP5000 is far more puncture and cut resistant. Wear so far, is better than the Pro One too. Looks like it will go 2000 miles or so. Pro One never got past 1500 on my bike.
    www.949Racing.com
    (what I do when I'm not riding)
  2. #27
    changingleaf
    Aug 2009
    Thanks for the review at 1200 miles. Looks good so far.
  3. #28
    Jun 2018
    Tubeless fan here too.
    Quote Originally Posted by upstateSC-rider View Post
    I'm a tubeless fan also, in fact I first converted my old Bontrager race wheels to tubeless back when Hutchinson was the only tire player in town and Stan's sold the kit. I got the feel of a tubed 25mm tire with my tubeless 23mm in an old Tarmac frame that wouldn't fit a 25. Weight is a non-issue for me also since they're fairly close and I carry a spare tube/CO2 whether I'm running a tube or not. I did have a flat with tubeless about 3 years ago when the initial run of Pro One's were released and proven to be fragile, a little messy but definitely not a big deal.
    I've only run tubeless since 2018, the first year when I went over 4k miles in a year. On the first 6mile ride on the first set of Schwalbe Pro One 25, I dodged a small piece of L-shaped metal and the front wheel/tire missed it, but the rear wheel did not. It put a 1 inch gash on the sidewall, and I insta-flatted. Messy, orange sealant everywhere. Luckily, I had a spare tube and a boot to get back home. After replacing the rear tire with another Schwalbe, this time a Pro One 28, I rode the remaining 4k miles on that tire. No flats in the remaining 4k miles. *** A few weeks ago, I decided to replace the rear tire, as the Schwalbe is clearly worn. The thread is squared-off. Stupid me, I decided to replace the rear tire a few hours before a long ride. Without an air compressor/tank. Needless to say, I was unable to get the Schwalbe Pro One 28 to seat into my HED Belgium+. So, I put a tube in the rear tire and hoped for the best. The ride was in the wet rain and of course, all manner of road debris would wash towards the shoulder of the road. After 80miles into the ride, I get a puncture, in the rear tire, where I have a tube. Luckily, I had a spare tube. But 5 miles after that, I get a slow leak. Time to patch the original tube, and this one let me finish the ride. After finishing the ride, I inspect the bike and I see a 1/4inch and 1/8 inch metal sliver in my front tire. I pull these out, and the sealant seals these up toot-sweet. The rear tire with the tube has gone flat, a few hours after the ride, probably another metal sliver or my patch job wasn't too good. I, for one, would welcome the day when there is a road tubeless standard that is easy to mount, easy to install (bead-seat) and sealant-optional. Maybe in a few years.
  4. #29
    Jun 2018
    But wider/fatter Schwalbe with lower pressure is more comfy.
    There is only so much chamois padding and saddles can do for comfort.
  5. #30
    Jun 2018
    Thanks for the 1200mile review.
    I have noticed that the Schwalbe Pro Ones do get a lot of cuts on the tread, at least in my situation.
    One point though is that the Conti GP5000s are for hooked rims only, which is fine for aluminum wheels. I'm eyeing the ENVE SES4.5AR rims for my next build but these are hookless rims, so the Conti's are not recommended, only the Schwalbe's.
    Bontrager Aeolus Pro 3V are hooked rims.
  6. #31
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    I would like to know what is the purpose of hookless rims? Is there any advantage to this design?
    "If someone needs 200 rolls of toilet paper for a 14-day quarantine, they probably should have made a doctor's appointment way before the COVID-19 outbreak." -- Unknown
    "With
    -- DCGriz, RBR.
  7. #32
    Jun 2018
    From bikeradar
    https://www.bikeradar.com/us/mtb/gea...he-hook-40749/
    However, for road tubeless, manufacturers such as Mavic and Continental have said that for pressures above 60psi, the hooks are needed to avoid blow-off.
  8. #33
    Aug 2017
    Quote Originally Posted by Emilio700 View Post
    which sealant do you use?
  9. #34
    Banned Sock Puppet
    May 2014
    Quote Originally Posted by Fr0hickey View Post
    From bikeradar
    Ahhh, lowers manufacturing costs. Nuff said!
    "With
    -- DCGriz, RBR.
  10. #35
    Sep 2010
    Quote Originally Posted by Rone69 View Post
    I use Orange Seal standard formula. As I race all my bikes, it needs to seal quickly. The downside is that you need to refresh the sealant about every 3 months.
    The GP5000 does mount a little easier than the Schwalbe. Acebike 46mm hooked bead rims. The Schwalbe required a little wresting and white fingers. The GP5000 no more difficult than a tight tube type clincher. I carry one steel core tire lever.
    I have now run through one rear but still on the original rear. Small cut in the front but sealed up just fine by itself. Rear was worn to cord (surprise!) and still held air without any new punctures. Overall, loving the tire. Just wish they cost less. To be fair, the Schwalbes were near $95 when first released but slowly dropped in price until now when you can occasionally find them for less than usd50.00
    www.949Racing.com
  11. #36
    Aug 2017
    Thank you very much Emilio.
    What about comfort, grip and descending quality, comparing the GP5000 vs the Pro One ?
  12. #37
    Sep 2010
    I think I covered that pretty well already in my previous posts?
    www.949Racing.com
  13. #38
    Aug 2017
    Sorry!
    Thank you very much.
  14. #39
    Aug 2017
    Have you run with Hutchinson Performance 11Storm TRL ?
  15. #40
    Sep 2010
    Nope.
    www.949Racing.com
  16. #41
    Reputation: kevina6's Avatar
    Apr 2017
    Picked up a pair of gp5000 TL 25c today but the just won’t fit my rims... can just about get the first bead onto the rim.
    Unfortunately they’ll have to go back.
  17. #42
    Sep 2010
    Quote Originally Posted by kevina6 View Post
    What rims, if I may ask? Hook bead tubeless specific I presume.
    Mine can just about be put on bare handed. Easier than the Schwalbe's were and way easier than the Hutchinson TL I tied a few years back. China Carbon tubeless, 21mm internal. Acebike I think.
    www.949Racing.com
  18. #43
    Apr 2017
    I have a set of bontrager Aeolus 5 carbon TLR wheels. There just too tight and won’t mount
  19. #44
    changingleaf
    Aug 2009
    Did you try mounting by doing the valve area last?
  20. #45
    Banned Sock Puppet
    May 2014
    Be sure to start opposite the valve end. Push the tire bead into the groove in the center of the rim. Work around both sides like that until you reach the valve end.
    "With
    -- DCGriz, RBR.
  21. #46
    Apr 2017
    Tried all that even the LBS could not mount them. Have gone with the ordinary non tubeless GP’s. The non tubless mounted in seconds
  22. #47
    Banned Sock Puppet
    May 2014
    The LBS couldn't mount them?? Oh brother!
    "With
    -- DCGriz, RBR.
  23. #48
    Jun 2018
    Thanks for the review. The GP 5000 is one of the tires I have been looking at.
  24. #49
    Sep 2010
    Update on price, finding them from online shops in the EU for $55 (usd) shipped to the US. Best way to google search is to use the brand and SKU from the Conti site: https://www.continental-tires.com/bi...d-prix-5000-tl
    XE.com will give you exchange rates, which are good this week.
    www.949Racing.com
  25. #50
    Apr 2017
    forget tubeless! Latex tube plus vittoria corsa or veloflex at the front for feel and control. Latex tube and Vittoria rubino or Conti at the rear for longevity.
    Tried same combination you found me absolutely agree with you (best control and best performance) but I am converting tubeless the same, why?
    1) ever thought about consequences of tube exploding (because of manufacture fault, rim heat etc...going flat in one second)
    2) what you do if flat twice or more in a trip? Bring with you many spare tubes? (me bring tubeless worms kit)
    3) rims now are tubeless ready means have to struggle both for mount and unmount whatever kind of tyre, I choose tubeless, ok are a bit harder, but less chances to mount/unmount
    (sorry for my not good english)
  1. Giant Gavia vs Schwalbe Pro One
    By ongbenghui in forum Wheels and Tires
    Last Post: 01-25-2018, 04:26 AM
  2. schwalbe pro one tubeless and Stans notudes tire sealant
    Last Post: 03-08-2017, 05:16 PM
  3. GP4000IIS or Schwalbe Pro One Tubeless?
    By eyeheartny in forum Wheels and Tires
    Last Post: 11-19-2016, 03:24 PM
  4. Durability of Schwalbe One vs 4000SII
    By TlfT in forum Wheels and Tires
    Last Post: 03-22-2016, 03:28 PM
  5. Replies: 12
    Last Post: 04-11-2011, 07:40 AM
