Handbuilt 32 spoke Wheelset vs Mavic Aksium etc
Results 1 to 10 of 10
    Jan 2016
    Hi all,
    I am cheap and am looking for the best value in a wheelset (within my budget, no HED Belgiums on 350 hubs for me). I am also a bike mechanic and have built a couple wheels, so I am comfortable with building wheels myself. I have a budget of about $200.
    There is a set of 2017 Mavic Aksium WTS wheels with Aksion 700x23 tires on ebay for ~$200 shipped. They are 1823g.
    I am also looking at building my own wheelset from Shimano 105 R7000 hubs, DT Comp DB spokes, and DT R460 32h rims. It should be about 1850g. This would cost me about $200.
    Is there any reason the Mavics would be a better wheelset? I am 170lbs and like racing crits and like taking my road bike on dirt occasionally.
    'brifter' is a lame word.
    Build your own wheels...even if you've only built a couple they're still better than Mavic.
    I work for some bike racers
    and a bunch of skateboards
    Reputation: Mackers's Avatar
    Dec 2009
    Just make sure you open up those hubs, regrease, and adjust carefully.
    The 105 hubs are amazing value and come with awesome quick releases but they neither come well adjusted nor well greased.
    changingleaf
    Aug 2009
    Your handbuilt wheelset should be more durable, but the bearings in the 105 hub are not the best. I would check the bearing preload too.
    I'm quite cheap too and I ride a ton of miles some of which is conditions harsh on wheels.
    One thing I learned over the years is that being cheap can get expensive.
    I don't know how much you ride and I'm not trying to imply you'll have issues with 105 hubs because I don't know them well but if you ride a lot it might be worth stepping it up to Ultegra.
    You'll definitely have those essentially forever and with your ability to build your own it'll only be like $50 when/if you burn though a brake track so spending a little more upfront on hubs may be the cheap way to go in the long run.
    Feb 2002
    In the immortal words of Al Kreitler: "The bitter taste of poor quality remains long after the sweetness of a good price is gone."
    [REDACTED]
    Reputation: Lombard's Avatar
    May 2014
    Quote Originally Posted by Honda Guy View Post
    This would be a far, far better wheelset than the Mavics, hands down! As Jay said, if you can spend a bit more, get the Ultegra hubs. Ultegra hubs have what is called digital adjust. What that means is that you can adjust the preload with your fingers (digits) and don't need cone wrenches.
    No.
    Quote Originally Posted by changingleaf View Post
    105 hub bearings will still be far better than the Mavic Aksium bearings. And DT460 rims are far better than anything Mavic.
    Nov 2002
    [REDACTED]
    May 2014
    If you have any skill in wheelbuilding, you're better off building yourself than going with Velomine. Velomine doesn't even stress relieve their wheels.
    Nov 2002
    There's nothing to prevent one from doing that when they get the wheels. Maybe the OP can, but I can't even get the parts for close to what Velomine sells a completed wheel for.
    Sent from my iPhone using Tapatalk Pro
  1. Aksium 2009 and Aksium 2011: are they different?
    By dot in forum Wheels and Tires
    Last Post: 04-07-2011, 08:20 PM
  2. Broken Spoke - Mavic Aksium
    By PegLeg in forum Wheels and Tires
    Last Post: 11-04-2008, 07:11 AM
  3. Snowblower story, pics....etc.etc.etc.etc.
    By physasst in forum The Lounge
    Last Post: 01-11-2008, 06:21 PM
  4. Replies: 0
    Last Post: 09-16-2007, 05:10 PM
  5. Replies: 11
    Last Post: 09-19-2006, 08:14 AM
