I'm obsessing... 24/28 Bitex hubs laced to...?
Results 1 to 25 of 36
    Reputation: krisdrum's Avatar
    Oct 2007
    I have a set of the Bitex 24/28 hubs that were floating around on here and other places sitting in my garage awaiting rims (from what I can tell the same as the 290g set from bikehubstore).
    My standard road wheels are a set of Easton EA70s (1620g, semi-areo around 26mm deep). I've had them since they were Velomax and called Circuits and have really liked them. I ride them as my everyday wheels.
    I'd like to build myself a set of lighter "event" wheels using the 24/28 hubs I have. I was pretty much sold on the XR270s, but then got to thinking the 380s would be cool (if not overkill in that hole pattern), as would dropping 100g off the 270 build and going with a set of 200s.
    I'm 170-175 with plenty of extra weight on me that I intend to get rid of over the winter. So, I'll be optimistic and say 160 in shape.
    Would I really notice a difference going from 1455g (270s with Laser/Rev spokes) to 1355g (200s with Lazer/Rev spokes)? And would the lighter rim give me issues building or in performance/durability?
    I am intrigued by the deeper 380s as well. But wonder if they are still a bit too new for me and expensive, if I am being honest. If I am going to drop $120 per rim, why not get some lighter carbon hoops for an extra $100 (Yes I know they can be had for less, but still significantly more than the other Kinlins).
    I intend to use the wheels primarily for my local spring crit series and fast group rides/races. I definitely want clinchers and something with different performance characteristics from the Eastons.
    Oct 2008
    Id consider going the other way and using something like a A23. That'd definitely get you something different.
    My xr300's laced to bitex hubs with regular sapim race spokes are only 1500g. Seems like 270's built with revs would be closer to 1400g even, and 200's even less.
    Oct 2007
    I think I'd rather avoid a wider rim, as these will be switched in and out and I'd hate to be adjusting my brakes with each switch. Although the wide rim concept is definitely one I am paying attention to.
    My calculations could be off on the weights, but pretty sure I figured about 5.5g per spoke & nipple, 290 for the hubset and 440g for the 270s. Adjusting the rim weights as needed for each model.
    Online Wheel Builder
    Reputation: Zen Cyclery's Avatar
    Mar 2009
    If you want more of a daily driver sort of setup, go with the XR270s. They will be a bit more efficient when trying to maintain average speed. The XR200s on the other hand will be a bit better for acceleration (or climbing) but will take slightly more work if your trying to maintain speed on the flats due to the lacking aerodynamics.
    So it really does depend on when type of terrain your usually riding.
    Apr 2011
    if your only using them race days, I would think you would be fine with the 200's with a 28 spoke rear at your weight. Have you considered going tubular? I'm in the process of building some alloy tubulars to use as daily riders so i can keep my carbon tubbies nice. I'm gonna use the kinlin tb-25 Bikehubstore just started selling them for $40 a rim. They weight in at 390grams which is the same as the xr200's but because of the tubular design they are MUCH stronger. not to mention the lighter weight of the tubular tires themselves really would let you get to a lightweigh set.
    Oct 2007
    I have very little to no interest in tubs for the road. Road racing is not my primary objective, and I'd rather save my gluing time for wheels I actually give about. I use nice clinchers (Veloflex) and have used Vittoria tubs on the road and frankly, I couldn't tell the difference.
    Zen - There is only 1 crit course here that is pan flat (an ex airport) and I have the Eastons (although heavier) that I could use for that course. The 200s are looking more and more appealing to get me something different from my current Eastons.
    Mar 2009
    Quote Originally Posted by krisdrum View Post
    If your logging vertical most of the time, the XR200s may be a good way to go. You could also go with a Stans Alpha 340 rim. This would be slightly lighter than the 200 and it would be tubeless compatible which would shave even more weight.
    Oct 2007
    Quote Originally Posted by Zen Cyclery View Post
    Not doing alot of vertical. More rolling hills. I am thinking more about constant accelerations in crit-eque situations.
    The Stans stuff has always intrigued me, but not at $120 a rim. I just can't justify that kind of dough.
    Mar 2009
    In that case, I think you should go with the A23. It will be a bit easier than the 200 particularly when trying to maintain average speeds due to its more efficient aerodynamics and its slightly higher rolling weight.
    Apr 2011
    why not go xr200 up front and xr 270 in the rear? BTW, the published weight of xr 270's is 440g. If i'm not mistaken, they tend to come in much less than that, like around 425g
    Mar 2009
    Quote Originally Posted by motobecane69 View Post
    Well I have seen them as low as 425, however they usually seem to come in slightly over weight around 445 grams.
    Oct 2007
    Sorry to drag this back up, but I'd like to get these ordered and build these over the holidays. So - XR200s or A23s? Debate.
    Again, I have a 1650g, 28mm deep set of Eastons I like and use as daily drivers.
    These wheels will be RACE only for events that require quick accelerations (crits). I'd love for them to feel very snappy and lively. I'd like to keep my budget under $80 per rim max, preferably under $50.
    Apr 2011
    i say xr200's are the no brainers based on everything you say. they are roughly 50 grams lighter per rim and they can be had from bikehubstore for 36bucks a rim plus shipping so right in your price range. your not particularly heavy and you've stated this will be race only anyways. maybe go with Race on the DS and Laser on the NDS and the front but if you want a little extra strength, go Race all around (though, I've heard that the combo of the heavier spoke drive side with the thinner, lighter spoke NDS is actually STRONGER because you get a better tensioned wheel.) I'll let a wheel guru answer that, I'm just a hobbyist.
    Mar 2009
    I think that the XR200 will provide a bit snappier feel due to their lower rotating weight. However, since crits are really all about corners you may want to go with the wider footprint of the A23. This will improve stability particularly when entering and exiting corners.
    Nov 2008
    A23s. It's all about getting around that corner as efficiently as possible.
    Feb 2003
    I weigh the same as you do now and have a set of wheels built with Kinlin 200s, 24/28, using a bikehubstore front and a Dura Ace 7850 rear hub. Spokes are Sapim Laser in front, 2x, and NDS rear, with W'S DB14 on the DS, laced 3x both sides. I use them for climbing and multi day touring events. While they give a smooth ride, I don't feel they are stiff enough to be doing a lot of out of jumps out of turns in a crit.
    I would look at doing a set 24/24, using Brandon's "wide" front hub, with Kinlin 270 rims. I have a set of wheels with Kinlin 270s, 20/24, and they are stiffer than the 200s with 4 more spokes. The 270 rims weigh a little more then the 200s, but you get some of the weight back by having 4 less spokes/nipples on each wheel. I'm going to build myself a set similar to this early next year using a CK front/ DA 7850.
    Oct 2007
    Ok, I won't fully commit, but I think you may have convinced me to go A23, even though they are almost double the price of the XR200s. Now the question... besides FairWheel (not that I have anything against them), where the heck can I get a 24 hole A23 at a good price? I'm trying to stick as close as possible to the $50 per rim as I can. Seems the higher spoke counts are out there and available reasonably close to that goal, but nothing on the 24 hole that I've found yet.
    Reputation: Bluechip's Avatar
    The only place I've seen the 20 or 24 hole is at Velocity's own website- $79.99.
    I found some 24h and 28h Velocity a23's at Joyride Cycles for $59.99 each with free delivery. I don't know anything about this company but I ordered them anyway.
    Oct 2007
    Quote Originally Posted by Bluechip View Post
    Thanks. That is a bit easier to swallow. Let me know how your experience with them goes.
    Nov 2008
    Too late, but speedgoat has good prices on these rims.
    Oct 2007
    Thanks. Good to know. Those are some nice prices. Too bad they are out of stock on the 24s.
    My Velocity A23's should be here tomorrow. Joyride has been very good with emails keeping me updated but shipping has been very slow. It took 14 days from time of order and payment to shipping. That seems like a long time to me for a supposedly in stock item.
    I ordered the hubs and spokes from Bikehubstore.com on the 23rd and they arrived on the 26th with Thanksgiving in between. That's what I call excellent service.
    Oct 2007
    Yeah, I called them yesterday, as I attempted to order just before Thanksgiving and the order didn't go through. It seems "in stock" to them means they can get it from one of their distribution houses. It does not seem like they have any physical inventory of these rims. Hence the extended wait, is my assumption. I think I will order tomorrow or Friday, just need to double check all my finances.
    Apr 2011
    you should have waited to get the rims before you ordered your spokes to be on the safe side
  1. Mavic hubs laced to Zipp rims
    By duralook in forum Wheels and Tires
    Last Post: 02-06-2008, 12:31 PM
  2. Can 32h hubs be laced 24h front, 28h rear?
    By mellowman in forum Wheels and Tires
    Last Post: 08-23-2007, 07:45 AM
  3. Weinmann DP18 rims laced to formula hubs???
    By marc180 in forum Wheels and Tires
    Last Post: 10-23-2006, 12:27 AM
  4. radially laced shimano hubs??
    By split in forum Wheels and Tires
    Last Post: 08-03-2005, 12:48 PM
  5. Anyone ever laced Campy hubs radially?
    By SDizzle in forum Wheels and Tires
    Last Post: 04-03-2005, 11:08 PM
