Inexpensive 700c Gravel Wheels
Results 1 to 23 of 23
    Dec 2015
    Looking for recommendations. Have 650b's now but would like to complelment them with a less rugged set of 700c's, maybe to run 40 mm or thereabout tires as opposed to 50's on the 650b's.
    Thoughts?
    tlg
    tlg is online now
    Reputation: tlg's Avatar
    May 2011
    Be less vague
    'inexpensive' is subjective.
    Some people think $200 is inexpensive. Others think $1000 is. What do 'you' consider inexpensive. Give a price range.
    Disc brake? Type of mounting?
    Carbon? Alum?
    Oct 2013
    I think he wants roound ones , don't forget that.
    BANNED
    Neophyte
    Reputation: jetdog9's Avatar
    Jul 2007
    Making the assumption that you're on disc wheels, I feel like you can get OEM take-offs or extra part wheelsets for a decent price in certain places like eBay or maybe randombikeparts.com... multiple brands use Formula for their OEM wheelsets. Scott/Syncros used to use DT Swiss but now also seem to use Formula for their lower/mid-end bikes.
    Example: OVAL CONCEPTS 524 DISC 700C wheelset would be an OEM Fuji wheelset made by Formula that you might find in the $200-$250 range.
    What are you calling a "gravel wheel". Extra wide rim?
    I and most people I ride gravel with use what they use on the road maybe with a few more spokes so I'm not really sure what a 'gravel wheel' is.
    Dec 2015
    Be less vague
    Carbon? Alum?
    Was thinking around $400. Disc brakes. Aluminum is fine.
    Budget bike
    Dec 2015
    Quote Originally Posted by jetdog9 View Post
    That would be nice. Really something wider and a little tougher than your typical road wheel. Want to run 40mm tires so it would be sort of mid-way between the 32s I have on one road bike and the 50s on the 650b wheels.
    changingleaf
    Aug 2009
    Wheels can be built in that price range with Bitex hubs and some Aluminum rims.
    Neophyte
    Jul 2007
    I understand the wider is better on gravel concept, have not gotten a chance to ride wider than what I have... but I'd also say my bike with 33's can handle any terrain that's been thrown at it so far. Seems like 38s are getting very popular?
    Dec 2015
    I have done some fairly rough trails on my Roubaix with 32 Gravel Kings, but the comfort and difference of going to 650b's with 50mm tires is remarkable. Did one ride in PA last year that even then I would have liked more (or a front shock system like the Lauf fork).
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    Round ones are boring. I like egg shaped ones.
    "With
    -- DCGriz, RBR.
    Banned Sock Puppet
    May 2014
    Quote Originally Posted by tommybike View Post
    As far as tougher, think higher spoke count - 32 spokes per wheel.
    40mm or thereabout is a good width for mixed on road/off road riding IMO. But why not just use these on your existing 650b wheels or get a second set of 650b wheels? That will also give you a little lower low gearing for steep hill climbs. Right now, I'm running a set of 650b wheels I built up last winter on my gravel bike with 650b x 42 Rene Herse Babyshoe Pass Ultralights and the ride is superb.
    "With
    -- DCGriz, RBR.
    Dec 2015
    Well part of the reason is that the 650s are busted and waiting a warranty from the manufacturer for 2 months. Thought 700s might be useful but actually not sure I could even go 40 with them, so it may be a tire switch. It's funny I was just discussiong the Rene Herse with someone on a ride today.
    Banned Sock Puppet
    May 2014
    Ahhh, another reason to go with another set of 650b's!
    "With
    -- DCGriz, RBR.
    Dec 2015
    But with a 700c set and a 650 b set I could switch out and try it as a gravel mullet bike. ;)
    Reputation: burgrat's Avatar
    Nov 2005
    Check Velomine.com. They have a few inexpensive wheel options for gravel.
    https://www.velomine.com/index.php?m...bjltd063dnqu41
    Dec 2015
    Quote Originally Posted by burgrat View Post
    Thanks
    Banned Sock Puppet
    May 2014
    One issue with Velomine is that they apparently do not stress relieve their wheels. They even have a note one the box saying that the wheels may go out of true after the first ride or two and need to be re-trued.
    "With
    -- DCGriz, RBR.
    Dec 2015
    Not good. Although I think I am taking this as an opportunity to learn how to fix my own wheels and hopefully build up a set, the site has a couple of kits. Once I get the one road wheel properly tensioned and a few test rides in, I may buy a kit or pieces and build my own. Covid hobby.
    Banned Sock Puppet
    May 2014
    I guess there is nothing wrong with buying Velomine wheels if you know how to build wheels properly, you can always stress relieve them yourself. I just am of the opinion that a builder who doesn't stress relieve their wheels is a poor wheel builder.
    If you are really looking for a "Covid hobby" as you put it, why not just build a set from scratch? That will give you a much better warm fuzzy feeling than fixing someone else's sloppy work.
    "With
    -- DCGriz, RBR.
    Dec 2015
    That is my objective. I saw a kit on Velomine which might be a nice first step. Working on truing and tensioning a wheel on my old road bike. Once happy with that I am planning on buying the pieces to assemble a set on my own. In the meantime reading Roger Muss's book.
    Banned Sock Puppet
    May 2014
    Great first step! Roger's ebook is probably the best investment you will make.
    "With
    -- DCGriz, RBR.
    Nov 2005
    I did not know that. Thanks for the info. That would certainly make me rethink buying a set there.
  1. Michelin Power Gravel 700C x 40mm?
    By The Gravel Snake in forum Gravel Bikes
    Last Post: 12-26-2018, 02:24 PM
  2. 26" Pisgah to 700c gravel bike
    By Pisgah2000 in forum Gravel Bikes
    Last Post: 06-13-2018, 11:54 AM
  3. Inexpensive, tough wheels for gravel riding?
    By maximus01 in forum Gravel Bikes
    Last Post: 01-03-2014, 01:43 PM
  4. Road/Gravel 700c Wheelset for up to 40mm tires.
    By RekibTaf in forum Gravel Bikes
    Last Post: 05-30-2011, 05:09 AM
  5. Possibility of 700c wheels when 27 inch wheels are stock
    By RalThunder in forum Fixed/Single Speed
    Last Post: 08-21-2007, 07:49 AM
