Kysrium front hub squeaks when weighted
Results 1 to 6 of 6
    JeffOYB
    Apr 2006
    Ksyrium front hub squeaks when weighted
    I have Kysrium hubs on my roadbike. When I weight the front end the front wheel starts intermittant squeaking. I also feel pulsing resistance. This seems bad. When I take the wheel out and spin it, it's free'n'easy. Spokes are all nice. What should I do?
    (i misspelled ksyrium kysrium then i fixed it.)
    'brifter' is a lame word.
    Sell them.
    Or, check the bearing preload/replace the bearings. Only good thing about Mavic wheels is they're easy to work on.
    I work for some bike racers
    and a bunch of skateboards
    Reputation: velodog's Avatar
    Sep 2007
    Sell them.
    There's a proper forum for this.
    Too old to ride plastic
    JeffOYB
    Apr 2006
    Oh, these are SSC wheels. I googled some more and found some good old info. I played around w the wheel and I see that there's a 5mm fitting for one end of the axle and a dimpled cone-cover sort of thing on the other side. Otherwise there seem to be 2 pieces on each side that rotate freely. Once you put a wrench in the end of the axle you can tighten or loosen the dimpled cover. The bearings play is side to side not "tilting." I'll try tighter and looser and see what is the effect. If creaking and intermittent resistance remains then I'll disassemble and clean.
    JeffOYB
    Apr 2006
    redoing cleaning etc didn't help at all. i'll see about replacing the sealed bearing catridges via my local LBS
    [REDACTED]
    Reputation: Lombard's Avatar
    May 2014
    Sell them..........
    ......to someone you don't like.
  1. Weighted Pedals?
    By jlandry in forum General Cycling Discussion
    Last Post: 02-24-2014, 10:33 AM
  2. Weighted Vest for Training?
    By nbpt15 in forum Racing, Training, Nutrition, Triathlons
    Last Post: 12-29-2009, 03:35 AM
  3. Roubaix Comp 07 - Squeaks and Groans
    By pjgray66 in forum Specialized
    Last Post: 06-18-2008, 06:20 PM
  4. Squeaks when shifting
    By Slip Stream in forum Components, Wrenching
    Last Post: 04-01-2008, 04:44 AM
  5. I feel weighted by 'stuff'
    By paint in forum The Lounge
    Last Post: 01-28-2008, 03:42 PM
