Which Lube
Results 1 to 19 of 19
Thread: Which Lube
    Which Lube
    I just got a set of wheels with the WI T11 hubs and the rear hub is real noisy. What would be the best oil to use to quiet it down. I heard either Phil Wood or something similar.
    'brifter' is a lame word.
    Do NOT use heavy grease in an attempt to make your hub less noisy. If you wanted a quiet rear hub you should have bought something else.
    ETA: I would not use oil either, it doesn't stay where it's needed and it will leak out and make a mess.
    I work for some bike racers
    and a bunch of skateboards
    Apr 2011
    T-11 are not quiet hubs to start with.
    Feb 2003
    Mine are VERY quiet......when I am pedaling. They don't bother me when not.
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    Interestingly, I came across someone who had a newer set of DT Swiss wheels which were very quiet, unlike older DT Swiss hubs which were noisy as f***. Or maybe it was the model?
    From the servicing instructions on their website:
    6. Clean out the ratchet ring area in the hub shell so that it is free of grease. Replace pawls and
    spring as needed and coat pawl and spring pockets with a light oil or dry lube (Fig.9). DO NOT
    GREASE.
    The all caps is direct copy/paste and and it's in bold when reading on their website.
    Unless someone screwed up at the factory yours already have the "light oil or dry lube" so there is nothing you can (or should) do.
    Reputation: velodog's Avatar
    Sep 2007
    Don't coast or ear plugs.
    Too old to ride plastic
    Nov 2002
    What do you use?
    I use the Shimano special grease, very light but it stays where you put pretty well. Just a bit in the WI hubs.
    If they were the higher end DT w/ the ratchet drive they were probably recently greased. The pawl hubs are not super loud so it could've been those. The 240 type hubs will be much quieter when newly greased then get progressively louder as the grease gets older. They're louder w/ carbon rims as well.
    Feb 2002
    90W gear lube tends to stay in place and is quieter than regular oil.
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    You ever work on a set of OnyxRP hubs? Even with carbon rims, dead silent. Love those hubs.
    Never Give Up!
    Mar 2009
    Is park Tool PPL-1 Polylube 1000 Polyurea Grease good for hubs bearings
    2010 Orbea Onix w/Ultegra R8000
    2007 IRONHORSE HT
    Quote Originally Posted by ROAD&DIRT View Post
    Loose ball bearings like Shimano or Campy? Sure.
    .je
    .je is online now
    Reputation: .je's Avatar
    Aug 2012
    I have a tube of Lubriplate 1200-2 (NLGI #2, Lithium 12 Hydroxy grease), for heavy-duty construction equipment.
    Is this grease suitable for Shimano loose-ball wheel bearings? I'm guessing it's not, and that regular white lithium grease is better.
    Quote Originally Posted by .je View Post
    You're guessing correctly.
    Feb 2002
    Probably a very stiff grease that would just get pushed out of the way by the pawls and not offer much lubrication. Alternatively it might keep the pawls from engaging. Neither outcome would be considered "optimum."
    Banned Sock Puppet
    May 2014
    IMO, if you are going to the trouble of taking the hubs apart, cleaning them and repacking them, just get the correct grease and be done with it:
    https://www.performancebike.com/shim...yABEgKcdvD_BwE
    changingleaf
    Aug 2009
    The newer 48 tooth ratchet on the White Industries hubs is much loader than the 24 tooth ratchet that the hubs used to come with. Use lighter grease. Any grease you use may quite the pawls for only a short amount of time. Once the grease spreads out the hub will sound the same as before.
  1. To lube or not to lube????
    By ralph1 in forum Components, Wrenching
    Last Post: 03-05-2008, 05:16 PM
  2. Chain Lube and Frame Lube
    By QuickBeamSS in forum Components, Wrenching
    Last Post: 08-20-2007, 11:51 AM
  3. Dry lube vs wet lube
    By Export A in forum Components, Wrenching
    Last Post: 07-10-2007, 07:40 AM
  4. Lube- that is, chain lube
    By filtersweep in forum Fixed/Single Speed
    Last Post: 06-03-2005, 04:17 PM
  5. Derrailer jockey pulleys, to lube or not to lube?
    By TACSTS in forum Components, Wrenching
    Last Post: 05-12-2004, 11:54 AM
