Are more engagement points better for road riding?
Results 1 to 15 of 15
    Jun 2005
    I have an old pair of MTB wheels with Chris King hubs that have 72 engagement points. It's a big advantage in mountain biking because there's so much coast-pedal-coast-pedal. It's great to have that next engagement point always right there.
    Does it make a difference for road riding? I know that DT Swiss makes hubs with high numbers of engagement points in their ratchet system, and I think that Easton's new hubs have high numbers of engagement points.
    Is it a disadvantage? More drag while coasting?
    May 2007
    It doesn't matter, but quick engagement feels nice. It can be draggier or not depending on the implementation. It can be more durable or less durable depending on implementation.
    If you have a 142mm king mtb hub and now you have a 142mm road frame, heck yeah i'd transfer the king hub.
    Reputation: Srode's Avatar
    Aug 2012
    I like the quick engagement option on the DT hubs, did not like at all the stock set up. Different sound freewheeling is all I have noticed. It would take a pretty sensitive test to assess a difference in drag I think - probably insignificant.
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Trek Crockett
    changingleaf
    Aug 2009
    I think it's personal preference, but generally the hubs with higher engagement cost more and even the DT Swiss 240 and 180 only come with 18 points of engagement out of the box, which is 20 degrees between engagement points. Onyx makes a very nice hub that has instant engagement, which some criterium racers like for putting the power back down quickly coming out out of corner.
    Nov 2002
    I think more engagement points are irrelevant for road biking. If it increases the noise level, then it's detrimental. I like a quiet bike.
    If it's an advantage it's rather curious that pretty much all pro riders and their teams who research how to go fast have decided to leave that advantage on the table and stick with ordinary road hubs.
    Aug 2008
    I agree that the advantage is limited for road use, although it could be argued that it could be beneficial for criterium racing. The argument that it's not advantageous because pros and teams aren't on them has little to do with performance and more to do with money (sponsors).
    Quote Originally Posted by andy13 View Post
    Performance and money are not separate issues. Better performance means more money through more exposure for sponsors. You really think sponsors are leaving a performance advantage on the table by not adding a few pawls to their road offerings?
    Aug 2008
    No, I think teams and riders think of sponsorship ahead of points of engagement.
    Reputation: velodog's Avatar
    Sep 2007
    Who needs more pawl engagement when running ceramic jockey pulleys.
    Too old to ride plastic
    Sep 2011
    The new Easton Echo hub has a 7deg engagement. I'd say it does feel a bit nice when you coast-n-go a lot, this happens to me when I'm trying to hammer on roads that have lots of cracks and chips and/or debris when I have to momentarily stop my pedaling.
    Those are light and reduce friction. But I'm only using them on my 'climbing bike' until I see the wind tunnel testing on various jockey wheels.
    Jun 2005
    How do you like those hubs @aclinjury ? I'm thinking about getting the Easton EA90 SL wheelset. I can also get those rims laced to Chris King hubs or DT Swiss 240s, but it would probably be an extra $300.
    Apr 2004
    For road cycling I don't think it makes a huge difference (to a point). However for mtbing where you are on and off the gas a lot you do want a faster engaging hub specially in such low gears.
    For me I find 10deg of rotation to be starting to be too much for the road. This is what a standard DT star ratchet does. Our hubs are at about 6.5-7deg which feels good. I think much faster than 7deg and it really doesn't make much difference for feel on the road. FOr mtb I would want 7deg or faster.
    Sep 2011
    Quote Originally Posted by TiCoyote View Post
    I love them, especially the rear. Rolls (on the bike) better than Chris King R45 (yes I've tested them against the CK R45 in a ramp roll down test). The Echo is quieter than the CK R45 and the DT Swiss 240, but a little louder than the Dura Ace hub. I'd take the Easton Echo hub over the CK R45. R45 definitely has more drag compared to DT 240, Dura Ace, Easton Echo, and Zipp 177 (in the Course 30 wheelset). So if it were me, I'd just buy the EA90 SL wheelset rather than paying $$$ to lace the rim up to a CK R45 and get an slower wheelset.
  1. Shimano Dura-Ace 7850, 7900 engagement points
    By grande in forum Wheels and Tires
    Last Post: 02-21-2010, 11:15 PM
  2. Engagement ring ideas?
    By YakuzaSmurf in forum The Lounge
    Last Post: 09-20-2007, 11:50 AM
  3. engagement rings
    By meathead in forum The Lounge
    Last Post: 01-06-2007, 08:53 AM
  4. Problems with Time RXS pedal engagement.
    By HouseMoney in forum Components, Wrenching
    Last Post: 07-27-2005, 02:18 AM
  5. American Classic Rear hub engagement
    By tmac13 in forum Wheels and Tires
    Last Post: 03-25-2005, 08:05 PM
