New Pacenti Forza Road Rim - Page 9
Page 9 of 9 FirstFirst ... 789
Results 201 to 220 of 220
  1. #201
    wut?
    Reputation: Clipped_in's Avatar
    May 2011
    Quote Originally Posted by Nessism View Post
    ...I bought some 9000 series Dura-ace hubs...
    Great hubs!!!
    There I was...
  2. #202
    Reputation: Nessism's Avatar
    Quote Originally Posted by Clipped_in View Post
    Great hubs!!!
    True that! The hubs roll so nice it's a pleasure working with them.
    And speaking of that, just finished building the rear wheel. My hands say I got the drive side tension pretty high; the Park Tool TM-1 tension app suggests I'm at 95-100 kgf (16.5-17 on the tool). Is this a good tension?
    BTW, the 24h rear rim weighed 483 grams and the completed wheel sans rim strip weighs 873 grams. CX-Ray non drive and CX-Sprint drive side.
  3. #203
    [REDACTED]
    Reputation: Lombard's Avatar
    May 2014
    If the Park TM-1 is calibrated correctly, your tension seems low. That being said, the Park TM-1 isn't a precision device. Do you have another wheel you can compare it to?
  4. #204
    Yes, I have other wheels, but not using the same type of spokes. I've always used round spokes previously.
    I'm not comfortable tightening more so my plan is to put the wheel into service and see what happens. If it won't hold shape or if tension falls off I'll go to a higher tension.
  5. #205
    [REDACTED]
    May 2014
    If you know the gauge of spokes and have the chart that comes with the Park TM-1, you can pretty easily find out how much tension your old wheels have and make a comparison.
    What kind of NDS tension do you have on your new wheel?
  6. #206
    I'm using the Park Wheel Tension App to get the conversion numbers. The NDS is running about 70kgf.
    https://www.parktool.com/wta
  7. #207
    Sep 2015
    The Park Tool chart shows CX-Sprint should be 18-19 max. CX-Ray should be 14 max.
  8. #208
    [REDACTED]
    May 2014
    70kgF on the NDS is plenty.
  9. #209
    wheelbuilder
    Reputation: ergott's Avatar
    Feb 2006
    There's no way the offset rim is giving you 70kg/100kg tension for the rear wheel. You have a NDS tension of about 57% of drive tension using Bitex hub and Forza rim. Park tension meters are essentially useless at low tension and shouldn't be relied on for any results under 80-90kgf. There's too much deflection due to high powered spring in tool.
  10. #210
    [REDACTED]
    May 2014
    Quote Originally Posted by ergott View Post
    Interesting. So I've been anal about NDS tension equalizing for nothing?? I release the tension meter very gently.
    So in light of what you say about, it looks like the offset rim gets you only a little improvement in DS vs. NDS tension disparities - 57% vs. 42%.
  11. #211
    Even if the gauge isn't super accurate, it does help balance tension in all the spokes and that's very handy.
    Based on feel the DS spokes are quite tight, and the NDS are what they are relative to that. If anything I think the DS might be too tight, reading 17 on the Park tool. Hopefully that's not the case though.
  12. #212
    wheelbuilder
    Feb 2006
    There are calcs that give resulting left:right tension % (the old spocal.exe is still out there for download). An offset of 2.6mm does help get NSD over my preferred minimum of 50-55kgf. The FSA tensiometer I use (currently available as Wheel Fanatyk model) uses much lower side load on spoke for better readings at low tensions. Still best to use meter on right side and correct left side evenness with relative pitch by plucking them.
    Sent from my SM-G950U using Tapatalk
  13. #213
    [REDACTED]
    May 2014
    Do you mean this one:
    https://www.wheelfanatyk.com/store/d...tension-gauge/
    Do you have a preference for the analog or digital one? I'm a bit of a Luddite, so I kind of like the idea of KISS and no batteries to run down with the analog version.
  14. #214
    wheelbuilder
    Feb 2006
    Mine is analog and serves me well.
  15. #215
    [REDACTED]
    May 2014
    Good to know, thanks!
  16. #216
    Nov 2002
    Why not use the tone of a plucked spoke to determine relative tension?
  17. #217
    Why lot use the tone of a plucked spoke to determine relative tension?
    Because in my opinion using tone adds more variation than using a gage.
  18. #218
    [REDACTED]
    May 2014
    I would concur here. But that may depend how good an ear one has. The tone method hasn't worked that well for me.
  19. #219
    Nov 2002
    Well, I think it's impossible to build a true wheel without some tension variation because rims are not uniform, especially at the rim joint, and thus balancing the tension by tone is much faster and perfectly acceptable and books I've read on wheelbuilding agree on this as well, but YMMV.
  20. #220
    Aug 2015
    New build with these.... Mounting a pair of used GP4000 23mm. SO difficult!!!
    Anybody else struggle to get some clinchers on these??
  1. Best road tubeless valve stem for Pacenti SL23
    By bobonker in forum Wheels and Tires
    Last Post: 08-16-2013, 11:34 PM
  2. Sette Forza Pro Ultegra VS. BMC Road Racer SL01 Ultegra
    By mike5734 in forum Bikes, Frames and Forks
    Last Post: 02-19-2013, 03:34 PM
  3. Sette Forza
    By TomcatD in forum Bikes, Frames and Forks
    Last Post: 10-17-2012, 11:54 AM
  4. Pricepoint Forza 105
    By Zeekster64 in forum Hot Deals
    Last Post: 11-25-2011, 10:50 PM
  5. First road bike since '97: Vilano Forza
    By sxharr05 in forum Beginner's Corner
    Last Post: 08-26-2010, 01:14 PM
