Novatec hub assplode
Results 1 to 14 of 14
    Aug 2010
    Some friends and I were heading down a descent at around 35 mph. Suddenly I hear a "tink" sound then my handling goes all wobbly. I stop and find out part of the front hub flange broke off and a spoke came loose and flew everywhere. Since this was a 20 spoke wheel it went extremely untrue and started rubbing off the carbon on the inside of my fork. It also left a few scratches on the outside of the frame and almost sheared my front derailleur cable in half. Has anyone else had this happen or know of this being a common issue with Novatec hubs? I'm sure I can get the hub warrantied but I don't think I'll use Novatec again if this is a common issue. The hub in question is an A291SB.
    Will the spokes be useable?
    How about the nipples?
    Will the rim be useable? When I span it after I let all the tension out of each spoke I saw it was still extremely untrue and had a hop vertically in it.
    Journeyman Wheelsmith
    Feb 2011
    How much tension was on the spokes? Radial lacing puts a lot of stress on the hub flange.
    Bob
    Aug 2010
    I'm not sure but the wheel was built by a professional wheel builder.
    Dec 2011
    If my experience is any indication, it's exceedingly rare. I'd guess I've built about as many wheels with those hubs as anyone, and ridden a bunch of miles on them, and they never give a peep of trouble. I'm guessing the hub shown isn't one I built since I'd have gotten an email about.
    We build fronts within the range of about 95 to 110 kpf, radial and 2x lacing (radial wheels get a bit more spoke tension than 2x).
    Feb 2002
    Quote Originally Posted by deviousalex View Post
    Ah, the beauties of low spoke counts and radial spoke patterns. Neither adds anything significant to wheel performance but "when good wheels go bad" the consequences are clear.
    Aug 2010
    Don't worry, my race tubular has even less spokes, 16
    A Story of Love
    Reputation: SystemShock's Avatar
    Jun 2008
    Sums it up.
    MH: I want to go like my Dad did peacefully, in his sleep, not screaming in terror like his passengers.
    Sys: COMPLACENCY IS LETHAL. VOTE in November.
    Homer: I believe that the children are our future. Unless we stop them now.
    Plat: I'd rather fellate a syphilitic goat than own a Cervelo.
    Seam: Saw Bjork poop onstage back in the day. It blew my teenage mind.
    Cranky Old Bastard
    Reputation: Randy99CL's Avatar
    Mar 2013
    Sram, for one, voids the warranty on hubs that are radially laced.
    "When you know absolutely nothing, anyone who knows 1% more than nothing sounds like an expert."
    Jul 2004
    "I'm not sure but the wheel was built by a professional wheel builder. "
    That doesn't mean he didn't over tension it.
    BUT....any hub can fail even when the wheel is built right.
    I had a King hub that was laced 3x that broke just like the picture.
    Stuff breaks. There are a billion of these hubs out there....how many do you see on here failing?
    Feb 2006
    That is a very light 60g hub. Novatech doesn't state the shell material, but IMO the higher strength alloys like 7075 are a poor choice here. Something like 6061 is better because of its resistance to stress corrosion cracking.
    Do you live or ride in a coastal environment, or ride on salted roads?
    The spokes can probably be reused, and the nipples if they were well lubricated. If the rim isn't straight, it's dead.
    Nov 2011
    Had the same thing happen to me on a front Novatec hub just the other day. Laced radially (20H) to 80Kgf, Sapim laser spokes and Velocity A23 rims. Definitely learnt my lesson here. No more cheap hubs or radially lacing.
    Feb 2011
    Quote Originally Posted by rruff View Post
    Actually, that looks like the standard "heavy " A291SB that weighs 76g. The A291SB-SL is the 60g version. It's thinner through the middle and has additional holes drilled into the flange area. I haven't used the SL hub and don't plan to either!
    A291SB-SL (Thanks, bdopcycling.com):
    Bob
    A Story of Love
    Jun 2008
    Quote Originally Posted by bobonker View Post
    Bob
    I guess SL not only stands for 'super light', but also 'stupid light' as well. Bummer.
    Aug 2010
    I live in the SF bay area and ride the coastal highway a fair amount.
  1. Ok to leave carbon bike in hot car all day/ (Will it assplode?)
    By RJP Diver in forum General Cycling Discussion
    Last Post: 07-29-2013, 02:00 PM
  2. Anybody use Novatec hubs in the mud and wet?
    By Sheepo in forum Cyclocross
    Last Post: 04-10-2012, 08:00 AM
  3. Will carbon assplode if hung on a car rack?
    By BostonG in forum General Cycling Discussion
    Last Post: 03-03-2012, 12:52 PM
  4. Does trek make good bikes? Does carbon assplode in the sunlight? Look here.
    By SOME_1_ELSE_1999 in forum General Cycling Discussion
    Last Post: 02-12-2012, 05:15 AM
  5. Will my iPhone assplode
    By q_and_a in forum The Lounge
    Last Post: 01-16-2012, 03:50 PM
