offset or center drilled rims (advantages/disadvantages)
Results 1 to 18 of 18
    Sep 2010
    Hi All
    is there a performance difference between center drilled vs. offset drilled rims? what are the advantages/disadvantages of each?
    tks
    'brifter' is a lame word.
    Performance? No difference. Wheel strength? Yes, because the tension between DS and NDS is closer to being equal. There's your advantage, there are no disadvantages that i can think of.
    I work for some bike racers
    and a bunch of skateboards
    Jun 2005
    Center drilled rims work better for lacing a hub that use 16-8 lacing (16 spokes DS, 8 NDS). Most offset drilled rims are intended for hubs that use the same spoke count on each side
    16-8 laced wheels definitely build w/more even tension between DS/NDS, however if you bust one of the 8 NDS spokes it's unlikely you'll be able to ride it home
    Many may disagree, but I like off center rims (OCR) for the back wheel. It helps keep the DS/NDS spoke tension more even & the spoke count between sides is the same.
    a little too stoked
    Reputation: SystemShock's Avatar
    Jun 2008
    I think I've heard complaints of offset rims being more prone to cracking @the spoke holes?
    Not sure why that'd be.
    MH: I want to go like my Dad did, peacefully, in his sleep, not screaming in terror like his passengers.
    Sys: Fake news?? Trump's a Fake President for God's sake.
    Plat: I'd rather fellate a syphilitic goat than own a Cervelo.
    Homer: I believe that the children are our future. Unless we stop them now.
    Seam: Saw Bjork poop onstage back in the day. It blew my teenage mind.
    Reputation: looigi's Avatar
    Nov 2010
    Quote Originally Posted by farva View Post
    Center drilled rims work better for lacing a hub that use 16-8 lacing (16 spokes DS, 8 NDS). Most offset drilled rims are intended for hubs that use the same spoke count on each side...
    You need to carefully look at the specific rim in question as some centered drilled rims alternate angles of the drilling. For example, HED c24 rims have all the holes exiting centrally and in line on the inside edge of the rim, but the drilling angle alternates, and in fact, the DS and nonDS drilling angles are different.
    ... 'cuz that's how I roll.
    Reputation: velodog's Avatar
    Sep 2007
    Quote Originally Posted by SystemShock View Post
    I've heard this same thing.
    I've got a 32 spoke 3x built up though and it sure makes for a solid wheel, but haven't had it long enough to tell if there's any truth to the rumor. Maybe 1500/2000 miles.
    I'd go the same route on a new set of wheels if an OC rim was available in the rim choice.
    Cranky Old Bastard
    Reputation: Randy99CL's Avatar
    Mar 2013
    This video shows the Velocity A23 OC rim and explains the advantages: Velocity A23 Off Center Rim - YouTube
    I had planned on using these rims for a set of disc cross wheels. With the rear disc hub I had picked the offset centered the spokes within 0.5mm. The spoke length was the same both sides.
    It makes sense to use the OC rims for front disc wheels also.
    "When you know absolutely nothing, anyone who knows 1% more than nothing sounds like an expert."
    Jun 2005
    Quote Originally Posted by Randy99CL View Post
    Great video. Thanks for posting
    changingleaf
    Aug 2009
    An OC rim will definitely build a stronger rear wheel than it's center drilled version. These rims become especially helpful to better balance spoke tension with the new 11 speed rear hubs.
    Sep 2010
    Thanks for the replies.. learned a lot!
    Sep 2010
    may I ask,, is the pacenti sl23, offcenter or center drilled?
    Online Wheel Builder
    Reputation: Zen Cyclery's Avatar
    Mar 2009
    The SL23 is centered drilling. An OC version of that hoop would be sweet!
    Sep 2010
    hi zen..
    just found this article
    Pacenti SL23 rim | Eric's Road Bike Racing & Training Blog
    says the pacenti is slightly angled.. I guess center drilled but angled?
    Mar 2009
    @echo7- The Pacenti has angled drilling which means the spoke holes are drilled specifically to the drive or non drive side. So while none of the spoke holes are truly centered on the rim it's still a centered drilling.
    A truly offcentered rim may still have angled drilling, but all spoke holes would be closer on the NDS side of the rim.
    Nov 2002
    The Pacenti SL23 is available in 24h center-drilled. I ordered a bunch to go with the 16:8 hubs I carry, even if the slight offset to the standard Pacenti 24h probably wouldn't render a 2:1 lacing impossible.
    Reputation: nhluhr's Avatar
    Sep 2010
    Quote Originally Posted by Zen Cyclery View Post
    Bumping this old post because I'm hoping you can tell me if the Enve SES 3.4 rim spoke holes are angled such that DS spokes should go through specific holes and NDS spokes through the others...?
    A wheelist
    Quote Originally Posted by looigi View Post
    My Pacenti are like that.
    Nov 2010
    FWIW: On the 24 hole Pecenti rim I have the holes alternate left/right but angles are the same so not DS/NDS specific, as far as I could tell, and could be used front or rear. The HED 24 hole rear-specific C2 rims had visibly different angles for DS vs NDS.
  1. Offset rims or not for disc brake wheels?
    By grs1969 in forum Wheels and Tires
    Last Post: 04-21-2009, 07:31 PM
  2. zero offset seatpost - advantages?
    By BigSur in forum Components, Wrenching
    Last Post: 10-27-2008, 01:48 PM
  3. Offset rims
    By Fantino in forum Wheels and Tires
    Last Post: 09-05-2008, 07:15 PM
  4. Performance advantages / disadvantages 52mm deep rim
    By G-Live in forum Wheels and Tires
    Last Post: 08-01-2006, 01:58 PM
  5. Powertap Pro vs. SL - advantages/disadvantages?
    By Larry Klassen in forum Racing, Training, Nutrition, Triathlons
    Last Post: 12-03-2005, 04:01 PM
