One more reason to stay away from Mavic??
Results 1 to 25 of 32
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    "With
    -- DCGriz, RBR.
    'brifter' is f'ing stupid
    I'm thinking '2 sides to every story' here. Especially the part where he says "and my front wheel hit another pot hole. He never says his rear wheel hit one...it would be very hard for the rear to impact a pot hole at that speed and not have the front hit the same hole. Did that happen and the first impact damage the front wheel and the second pot hole finish it off? My feelings about Mavic product in general are well known but this may have happened w/ any carbon wheel, hard to say.
    #promechaniclife
    Banned Sock Puppet
    May 2014
    I thought there were 3.
    That's what I was thinking, but I just couldn't resist another jab at Mavic. I've never been sold on carbon rims. There are just so many good quality lightweight alloy rims at a fraction of the price, it's just not worth it IMHO.
    And I may have opened up another can of worms here, but just to be ahead of the possible replies, no, just no to Chinese no-name carbon rims.
    "With
    -- DCGriz, RBR.
    3, you're right...I forgot 'the truth'.
    There are some crazy strong carbon rims out there, a lot of the mtbs we sell have them and w/ the exception of the Bontrager rims, especially the Kovee, we don't see many broken ones.
    #promechaniclife
    Banned Sock Puppet
    May 2014
    I am assuming the "crazy strong carbon rims" are either very expensive or as heavy as an alloy rim. Light, strong, cheap..........pick two?
    My point was with so many good quality, affordable, light weight alloy rims, is there any real reason to go carbon? Granted you work for racers and I ride for fitness, so our perspective may be different.
    "With
    -- DCGriz, RBR.
    For road use you can have a rim that's much more aero and the same weight. Add stiffer, and I'll add stronger to a degree. From a wheel builders view point they are more accurate...more 'round'. Aluminum rims are much more easily damaged in shipping and handling so you start off w/ rims that are slightly less 'round'.
    #promechaniclife
    Banned Sock Puppet
    May 2014
    I hadn't thought of the aero thing, but you're right about that. But since I don't race, I'm not terribly concerned about aero.
    And I guess if you build lots of wheels, having one damaged in shipping and being warped happens. I have 5 wheelsets I've build and never come across a rim not round and true out of the box. But I don't build ridiculously light wheels either.
    "With
    -- DCGriz, RBR.
    Cleavage Of The Tetons
    Reputation: rideit's Avatar
    Feb 2005
    This thread drift is a little ironic to me. Between, say, 1995 and 2005, Mavic rims were the best, most round, and easiest to build rims available, period.
    Shame how low they have fallen.
    Holy Crap. I assume the close up picture of the road at 4:02 is one of the 'pot holes'.
    That's nothing.
    Banned Sock Puppet
    May 2014
    That's nothing.
    In the video, it doesn't look like much, but consider he WAS barreling down at 45mph.
    "With
    -- DCGriz, RBR.
    That's still nothing. Unless the picture is an optical illusion I wouldn't expect a pinch flat never mind two completely trashed rims at any speed.
    Quote Originally Posted by rideit View Post
    Wayyyyyy before 1995. They made the first aluminum rims in the 30's. The SSC was the go-to tubular rim for pro and amateur racers throughout the 70's and into the 80's. Millions of wheels were built w/ Mavic rims for decades. The double eyelet Open Pro is probably the most used rim of all time. 32 spoke, 3x, Shimano hubs...295/293 rear, 295 front. I built a TON of those.
    #promechaniclife
    Reputation: Srode's Avatar
    Aug 2012
    Disc Brakes rock!
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Niner RLT9 RDO
    BH G7 Disc
    Trek Crockett
    Banned Sock Puppet
    May 2014
    Disc Brakes rock!
    I'm sure CXWrench can give us some examples where disc brakes overheated and failed on long downhills.
    "With
    -- DCGriz, RBR.
    Aug 2012
    I would be interested in hearing them if there are any, particularly if they aren't the dumbass move type failures.
    Gravel Rocks
    Trek Domane
    Niner RLT9 RDO
    BH G7 Disc
    Trek Crockett
    Feb 2005
    I guess I was referring to MTB. The venerable 231 is where I started with their dirt rims. 264/266 with any Shimano hub! (32 hole 3x, front 261 or 262 2x)
    I still see it all the time. It's always operator error...people still seem to think the back brake will slow you down effectively...and for some reason they're scared of the front brake.
    #promechaniclife
    Aug 2012
    And that would be the dumbass mode. Curious though, what do you see with such failures, rotors warped?
    Gravel Rocks
    Trek Domane
    Niner RLT9 RDO
    BH G7 Disc
    Trek Crockett
    Banned Sock Puppet
    May 2014
    Yep, that's what I was thinking. Using only the rear brake will require more brake force for the same amount of effective braking than the front.
    Didn't you mention awhile back seeing the Al core on discs melt?
    "With
    -- DCGriz, RBR.
    tlg
    tlg is online now
    Reputation: tlg's Avatar
    May 2011
    With light braking, it would be the same force. There's enough friction between either tire to slow the bike. There's actually more weight distribution on the rear wheel. With slow/light braking the rear is actually more effective.
    But with heavy braking, it will never be as effective. Heavy braking causes the mass to shift forward, reducing the friction between the rear tire and the ground. At maximum braking Nr=0 creating zero friction on the rear tire. Increasing brake force will just lock up the wheel and skid. And of course, if braking downhill it's amplified.
    Yeah, but rotors warp anyway. Overheated rotors and pads and the resultant 'glazing' which will reduce friction.
    On a downhill you'll never get the same amount of slowing down w/ the rear that you'll get w/ the front. As tlg posted, on flat ground and slower speeds the rear works fine, but when you are going faster, need to slow down more, and are descending, the front brake works better because of the shift in weight. Proof of this is easy to find...look at car and motorcycle brake systems. Especially sport bikes/road race bikes. 2 very large rotors and 4 piston calipers on the front and 1 small rotor with a 2 piston caliper at the rear.
    And yes, I've seen the core melt a little in IceTech rotors a couple of times.
    #promechaniclife
    Reputation: Notvintage's Avatar
    May 2013
    Disc Brakes rock!
    Itís marketing genius for sure. Convince clowns to by carbon clinchers (knowing they are a poor choice and prone to overheating with rim brakes), and then sell to said clowns/newbies they need dork discs on road bikes.
    Banned Sock Puppet
    May 2014
    Quote Originally Posted by Notvintage View Post
    OK, Boomer.
    "With
    -- DCGriz, RBR.
    Blah blah blah, blah blah...blah blah blah.
    Blah blah.
    Blah.
    #promechaniclife
    May 2013
    OK, Boomer.
    nope. Gen-X.
  1. Replies: 0
    Last Post: 02-09-2012, 07:52 AM
  2. one more reason to stay off the MUT
    By asciibaron in forum The Lounge
    Last Post: 10-18-2011, 12:41 PM
  3. one more reason not to buy GM
    By Export A in forum Politics Only
    Last Post: 02-03-2009, 10:45 AM
  4. One more reason to like Elvis Costello
    By firstrax in forum The Lounge
    Last Post: 01-24-2009, 04:22 PM
  5. One More Reason NOT to live in Wa. State.
    By OldEndicottHiway in forum Politics Only
    Last Post: 02-14-2008, 07:29 PM
