Opinions On New Tires - Page 2
Page 2 of 2 FirstFirst 12
Results 26 to 26 of 26
  1. #26
    Sep 2011
    Nice! I'd expect you'd not love really low pressure if your style is like you say. I worked w/ a guy that pushed the front end really hard in corners and just couldn't go below 25-27 or he'd feel the tire starting to roll over. I don't have your skills on the mtb
    now you said you setup your pressure for the conditions you ride in 99.9999% of the time and not worry about the .000001% of the time that'll get a pinch flat, and that is because you don't blindly run over objects. I use same logic for the road. However, for dirt, I set up my bike not for the 99.9999% but the .00001% where I might do a huck and land on a root or an edgy rock, which I have destroyed 2 rear rims due to too low psi. Low psi is great if you're looking for a supple ride, which is what most people looking to do. But if like to hit it in berms and camber hard to g-out, then personally I prefer higher psi for a stiffer feedback to the handlebars (nothing kills confidence faster than jello feeling in a g out), and I even prefer stiffer shock settings too, short travel and stiff. I'm not a downhiller so I don't like long cushy suspension bikes (sucks on climbing too), i'm more of a roadie who came from bmx/dirtjump background, so I have always setup my bikes (road and mtb) to be stiff.
    having said that, so i checked the psi of my tires this morning, apparently I let out enough air yesterday to set 18psi for the front, 20psi rear, one extreme to another
  1. New Tires, Need Opinions
    By RoadBoy1 in forum Wheels and Tires
    Last Post: 01-08-2013, 09:43 AM
  2. Tubular Tires - New to Tubies - What tires?
    By matthewtucker in forum Wheels and Tires
    Last Post: 11-14-2008, 06:06 AM
  3. New Bike; Keep new wheels & tires or switch to old wheels & tires
    By g8keyper in forum Components, Wrenching
    Last Post: 07-31-2008, 07:29 PM
  4. New wheels & tires. Tires r peeling of peeling off
    By brentster in forum Wheels and Tires
    Last Post: 04-13-2008, 05:55 PM
  5. tires, tires, tires
    By sparky821 in forum Commuting, Touring and Ride Reports
    Last Post: 01-22-2008, 03:39 PM
