• 03-17-2020
    mosinglespeeder
    Panaracer GK SK 40mm question-problem
    Hey guys, i have a question, not to be a newbie here but I feel like it after wrestling these new Panaracer GK 40mm tires.* Here is my issue, I mounted them w/tubes first just to see how they would roll out before going tubeless and noticed immediately a big stinking lump/bump/thump spinning her in the stand.* No biggie I thought, put the other in and same darn thing, now up front and back.* They had both been in the shed w/the bike over winter and i thought no biggie again, its stiff, it'll roll out, and deflated them down, massaged them out and really didn't find any problems or where they didn't hook up or anything wrong..so being optimistic, no biggie, will just ride out easy and it'll smooth out.
    only one problem, it didn't.**it was rough, lumpy and bumpy...like seriously and i had to back off and soft pedal home and couldn't go more than 20mph without a serious hop...so...no good.
    So i started thinking, and couldn't think of anything.* Changed tubes to be sure they weren't disproportionately displacing pressure or anything...nothing
    no change
    so after dickin around with these things, I see the bulges and lumps are in vertical seams on the tires, but am unsure of what to do.* Do you guys think a warm day in sun will help work it out or should i get another pair and send these in to replace??**
    Any ideas???
    thanks a mil ahead of time, i need help
    dano
  • 03-18-2020
    cxwrench
    What are all of these *** for? Were the ** tires folded during the *** winter? If so let them warm up and see what happens. **$&%@@
  • 03-18-2020
    mosinglespeeder
    yes cxwrench...what the @@??
    I didn't put that in there, must have been some rank virus...
    sorry, but will try that, thanks
    they were cold all winter in shed, I think stiff and will see if it mounts up better and seats in, I think it's not seating in the bead
    thx on that, sorry for the ^^^ extras
  • 03-18-2020
    Srode
    should be able to see it if they are seated on the bead. If they aren't, try breaking them down again and put a generous slathering of dishsoap on the tire bead.
  • 03-19-2020
    Lombard
    Check the bead seams carefully. If they are not straight around the rim, it's a mounting error where tires aren't properly seated. Could be potentially hazardous.
  • 03-19-2020
    mosinglespeeder
    well that was it, the bead wasn't seated in. I think it was a combo of tubeless beefy SK side walls and being folded over the winter, and cold temps in the shed, after I worked with it over night, pumped up to 60psi and put in the window w/70 degree sun, she popped on and is perfect.
    thanks for the help guys!
    dano
  • 03-19-2020
    Kerry Irons
    The absolute very first thing to do with a lumpy tire is simply look at it to see what is going on. I would hazard a guess that 95% of the time it is due to the tire not being properly seated on the rim, which is painfully obvious when you slowly rotate the wheel while looking at where the tire meets the rim.
