Is it possible to chip a CF rim installing tires?
Results 1 to 5 of 5
    Jun 2005
    I was putting on a new set of Continental GP 4000 IIs on a pair of aluminum rims, and the only way I could do it was with the Tire Bead Jack. I was thinking about how much stress this puts on the rim, and sometimes the jack slips off and snaps across the rim.
    I've never owned carbon rims, but that's not to say I never will. Is there a danger of chipping or cracking the lip of the rim when installing tires? Are there special precautions?
    Oct 2017
    it is absolutely possible to damage a carbon rim installing a tire - particularly using the wrong type of tool.
    tlg
    tlg is online now
    Reputation: tlg's Avatar
    May 2011
    I have a tire bead jack. Have used it on carbon rims with tubeless tires. No issues. I've never had it slip off like you say. Not sure why yours is.
    Yes, you could chip/crack a carbon rim if you do it wrong. I'd be much more concerned with tire leavers chipping carbon rims though.
    'brifter' is a lame word.
    Definitely possible. If you're having these problems you might want to have a very competent mechanic show you how to accomplish certain jobs.
    I work for some bike racers
    and a bunch of skateboards
    changingleaf
    Aug 2009
    Iv'e seen them chipped with screwdrivers, but plastic should be safe.
  1. paint chip or crack on cf
    By xlent in forum General Cycling Discussion
    Last Post: 05-28-2018, 11:00 AM
  2. Chip in CF fork crown... Repair?
    By mhickey79 in forum Cyclocross
    Last Post: 02-09-2011, 10:22 AM
  3. CF Fork Shudder and used CF bike
    By DrDitto in forum Bikes, Frames and Forks
    Last Post: 10-03-2008, 05:31 PM
  4. Thinking about buying this frame w/ CF clearcoat chip
    By Mad_Hun in forum Bikes, Frames and Forks
    Last Post: 09-18-2008, 07:03 AM
  5. Chip, Chip, Chipping away...
    By thatsmybush in forum Politics Only
    Last Post: 06-21-2004, 02:35 PM
