Real thru axle vs QR convertor
Results 1 to 4 of 4
    Apr 2019
    I'm planning on building some wheels and am looking at the options. My frame is made for QR and is currently running 9/10mm thru axles which I think feel better than the original QR (could be psychological purchase justification...) The problem is 9/10mm thru hubs are rare, and the most common Shimano ones the freehub is prone to cracking. The other option is Hope but I can only find them with an alloy freehub which I'll chew up...
    Looking at 12mm to QR convertor axles they are going to be machined so surely they will be solid with a 5mm hole through the middle and nearly as stiff as a real axle, especially with the skewer filling the hole? But if they are why wouldn't at least some hub manufacturers just use a solid middle on their QR hubs? Maybe they do and I missed it?!
    Hope has a steel freehub option.
    Nov 2014
    Like you, I've used adapters on a couple of bikes to run through axles in QR frames and forks. From here FWIW https://www.ebay.com/str/mtbtools?_t...p2047675.l2563
    Unless the rear end of your bikes is spindly, or you're a monster sprinter, I don't think it's all that necessary on the back even with discs. On a disc fork, sure you can really notice the difference.
    Apr 2019
    Quote Originally Posted by Enoch562 View Post
    That they do, I found a place that will sell me a steel/10mm/135mm but it won't ship for a couple of weeks. The only other option is to buy an alloy/10mm/135mm and a steel freehub but that's expensive (nowhere has the 10mm adaptor and the hub)
    Quote Originally Posted by harryman View Post
    Actually I haven't used any adaptors but did see those - tempting apart from the import tax/fees which will cost nearly as much as the adaptor.
    I'm already not enjoying this wheelbuilding lark and I'm yet to start!
  1. Road Discs- Post vs Flat mount and QR vs Thru Axle
    By TDFbound in forum Bikes, Frames and Forks
    Last Post: 08-29-2017, 09:21 AM
  2. Which axle/Skewer for gravel bike? QR vs QR-9
    By mummer43 in forum Gravel Bikes
    Last Post: 03-02-2017, 09:59 PM
  3. Ultegra 800 FD Cable Routing and convertor position
    By dgs_bikes in forum Components, Wrenching
    Last Post: 09-08-2015, 09:45 AM
  4. DT Swiss 240s Centerlock QR to 15mm thru axle
    By deviousalex in forum Wheels and Tires
    Last Post: 06-05-2015, 09:56 PM
  5. Anyone installed a digital convertor box yet?
    By Dave Hickey in forum The Lounge
    Last Post: 01-03-2009, 07:59 AM
