releasing pump hose from tire noise
Results 1 to 5 of 5
    Jan 2009
    When I release there is loud "explosion." Anyway to reduce this? Grease valve?
    It doesn't happen with all tubes. Is this good or bad/ inevitable thing?
    Reputation: krisdrum's Avatar
    Oct 2007
    Explosion or rush of air out of the pump hose? The air in the pump hose is pressurized to the same psi that you are filling your tire with, so you are going to get a rush of air when you disconnect the hose regardless. Not sure what you mean by explosion, but that to me usually indicates you haven't properly seated the tire and the tube has gotten itself caught inbetween the tire and the rim and has burst.
    Reputation: PlatyPius's Avatar
    Feb 2009
    It's air from the hose, not air from the tube.
    ie: It's a non-issue.
    Other countries need to stop hatin' or we'll unfriend them. - Christine
    Apparently I left my reading comprehension glasses in my ass. - DrRoebuck
    Still, it felt great and I felt like I was sitting on some kind of vibrator -Touch0Gray
    Reputation: JCavilia's Avatar
    Sep 2005
    Quote Originally Posted by PlatyPius
    What he said. And if your pump has a built-in guage, there's often a reservoir to stabilize the pressure (so the guage reads more accurately), so the air release is pretty large.
    I assuming you're using Presta valves, and if so there's nothing to worry about -- all that air is coming from the pump and not the tire.
    Stay Fit!
    Reputation: eyezlee's Avatar
    Nov 2009
    Scares the shih outta my shih tzu's. Normal noise at my house, its a non-issue.
