Rim Strips
Results 1 to 25 of 48
Thread: Rim Strips
    Rim Strips
    Just wondering if anyone prefers either Velox tape or the Zipp or Conti plastic rim strips
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    Quote Originally Posted by Stew View Post
    I use Velox strips, but some here prefer others. I run tubed clinchers. I don't think you can use these for tubeless setup.
    "With
    -- DCGriz, RBR.
    Schuylkill Trail Bum
    Reputation: SPlKE's Avatar
    Sep 2007
    I use the conti plastic strips. They're easy to put on and take off, and they seem to last forever.
    No, no and no.
    Stans yellow tape.
    Jan 2010
    No, no, no and no again
    Scotch Film Strapping Tape 8898 Ivory, 24 mm x 55 m
    why 2 identical threads?
    There's sometimes a buggy.
    One.
    tka
    tka is offline
    Jun 2014
    Banned Sock Puppet
    May 2014
    Quote Originally Posted by bikerjulio View Post
    Nope. Too wide.
    "With
    -- DCGriz, RBR.
    Jan 2010
    Nope. Too wide.
    Thanks for letting me know. Now I'll have to go back and redo all those rims I taped using this.
    There you would be wrong. It fills the rim bed perfectly. This has come up in the past, and this is the tape that at least one commercial wheelbuilder uses.
    Try some research. Like this: http://forums.roadbikereview.com/whe...-a-354076.html
    One.
    grizzly moderator
    Reputation: dcgriz's Avatar
    Feb 2011
    Another vote for Stan's tape. I use two layers on everything I build which is mostly for tubed tires.
    With bicycles in particular, you need to separate between what's merely true and what's important.
    Banned Sock Puppet
    May 2014
    Hey, if it works for you, great! I am thinking it would make tire mounting more difficult. 19mm worked for me on both my builds - HED C2s and DT R460s. 16mm is too skinny.
    "With
    -- DCGriz, RBR.
    Nov 2013
    From what I can gleam reading various forums, Stan's is really rebranded Tesa 4289, Pacenti tape is rebranded Scotch 8898 (which usually comes in a blue color), and American Classic is rebranded Kapton tape.
    For tubed clincher setups it probably doesn't matter what you use. However for crazy tight tubeless rim/tire combos, Kapton is king as it's thinner which makes mounting tires easier (and it's lighter and less stretchy to boot).
    Dec 2011
    Moral of the story is lots of stuff works. We've settled on two widths of Tesa (nominal 1" for 20mm internal, nominal .75" for narrower - although the narrower works fine for wider rims too) and it works like a champ. I know that Industry Nine uses straight up Tesa as well. It stays put really well. If you get a good technique with your thumb, you can get the tape REALLY stuck down into the channel and the whole install is quite quick. You have to be extremely aware of thumbnail length though, otherwise you split the tape. A friend told me he had that happen - certainly such a thing has never happened to me!
    Kapton is really good for tight fits, as cooskull says. It's not only wicked thin, it's wicked slippery so the tire climbs out onto the shelf readily. The things you have to watch out for with that are that if you pull it too tight on install, it frequently explodes when you pierce the hole for the valve stem (same friend told me about that) and it is a PAIN IN THE STONES to remove if you should have to. I just retaped a set of my wheels today (changed hub color - yes, I'm a pretty princess when it comes to that stuff) and the hardest part of the whole deal was getting the stupid Kapton off. Our personal wheels get whatever off cuts, rejects and cast offs are hanging around, which is why they had Kapton in the first place.
    Jan 2012
    I've used Velox with tubed clinchers for years.
    Jul 2008
    Nope. Too wide.
    Not for a HED + rim.
    Nov 2013
    Quote Originally Posted by November Dave View Post
    I can personally vouch that Kapton tape will split by the valve stem hole if it is stretched too tight. I have had two occasions (front and rear wheels) where I found this only after it was time to replace the tire. Fortunately the tape never failed catastrophically- either due to luck or the tape's superior adhesion properties, I don't know.
    However, my experience with Kapton tape was quite different from yours as far as residue. Even after riding in temperature extremes from 30 to 100 degrees with it installed, it's removal has been super easy and absolutely residue free. I can only guess that there are cheaper versions of the tape out there that use inferior adhesives?
    Filament strapping tape on the other hand is certifiably the ultimate nightmare to have to take off (only tried that experiment once to find that out the hard way).
    Mar 2013
    Quote Originally Posted by tka View Post
    That's exactly what I use, works perfectly!
    Reputation: FeltF75rider's Avatar
    Feb 2012
    I prefer Velox but that Kapton tape might be worth a shot.
    Jan 2010
    Quote Originally Posted by Bikephelps View Post
    1990 called. They want their tape back.
    One.
    Jan 2010
    Quote Originally Posted by cooskull View Post
    The tape I suggested, Scotch Film Strapping Tape 8898, does not spontaneously split, nor does it leave a residue. it's also pretty thin and slippery. So I'm not seeing why it isn't #1 here.
    One.
    Nov 2013
    For the record, the split was a few millimeters wide. This could pose a potential danger for tubeless setups, but is a non-issue for tubed setups.
    But yes in most cases it six of one, a half-dozen of the other as to picking what works. Some people go "ghetto" and use duct tape or Gorilla tape and that suits them just fine (at least until they have to take the tape off for some reason).
    My personal recommendation is that if someone goes the tape route, do get the original equivalent of the Stan's/Pacenti/AC. Paying 6x the price for a relabeled product just doesn't make any sense.
    Banned Sock Puppet
    May 2014
    Quote Originally Posted by Blue CheeseHead View Post
    But for an HED C2?
    "With
    -- DCGriz, RBR.
    Jan 2010
    But for an HED C2?
    First you question me. Which was a mistake. You did no research either before or since.
    I guess you didn't bother to read my link. Too much work?
    We buy it by the mile, have been using it for around 8 months. The 1" width is perfect for 18 to 20mm bead seat widths. By the time it drops down into and conforms to the channel, it's not too wide.
    One.
    Banned Sock Puppet
    May 2014
    Point taken. No need to get snarky.
    "With
    -- DCGriz, RBR.
    Not that this minutia matters for tubed clinchers but, seriously dude, try something else.
    Give clipless pedals a try while you're at it
    Good thing you didn't question anyone's choice of chain lube. That could get violent.
  1. I've had it with rim strips !
    By nick2ny in forum Wheels and Tires
    Last Post: 07-24-2015, 09:23 AM
  2. non-moving rim strips?
    By framesti in forum Wheels and Tires
    Last Post: 10-16-2010, 05:50 PM
  3. DT 1.1 and Zipp Rim Strips
    By JulesYK in forum Wheels and Tires
    Last Post: 06-22-2009, 04:31 PM
  4. rim strips
    By soiled chamois in forum Wheels and Tires
    Last Post: 04-08-2008, 04:05 PM
  5. rim strips
    By bob-e in forum Wheels and Tires
    Last Post: 03-18-2005, 05:07 PM
