Rim Tape Width
Results 1 to 25 of 25
Thread: Rim Tape Width
    Reputation: Notvintage's Avatar
    May 2013
    Rim Tape Width
    I have a set of ALForce 33 wheels coming and was wondering what rim tape width to go with. NOT tubeless tape, but normal clincher tape. I was thinking 17mm. Not sure.
    Feb 2003
    I built a set of wheels using the AL33 a couple of years ago.....great wheels. I bought everything from Bike Hub Store and used this rim tape, in 21mm: https://www.bikehubstore.com/product-p/velotape.htm Its been fine for me.
    Reputation: velodog's Avatar
    Sep 2007
    If the rims are tubeless ready you may be better off using tubeless tape. The tolerances are probably tighter to get a good seal and conventional tape will most likely make mounting tires tougher, 'specially considering the added mass of the tubes.
    I know that I had to rip Velox out of a tubeless ready rim and replace it with tubeless tape to take the chore out of mounting tires. I choose tubes, but don't think that mandates using cloth tape.
    Too old to ride plastic
    I think it's just better period regardless of rims being tubeless ready or not.
    Feb 2003
    The like I posted for the OP was for a "tubeless tape".
    May 2013
    Quote Originally Posted by cdhbrad View Post
    LOL . . It was like 3am.
    Feb 2003
    Should have said "link"......all I know is what I showed you works just fine on an AL33. I don't use cloth tape anyone on any rims. If you get caught in a rain, they can soak up water from the water running up the spokes and past the nipples. Not a problem with the tape I showed you.
    May 2013
    Thanks. I'll give it a shot.
    changingleaf
    Aug 2009
    2 layers of thin tubeless tape is the way to go on those rims regardless of use, tubes or tubeless.
    May 2013
    Quote Originally Posted by changingleaf View Post
    Who makes what you'd consider "thin" tubeless tape? I ask as I'm not familiar with tubeless tape.
    Feb 2003
    The brand I linked you too is pretty darned thin and BHS supplies products to many wheelbuilders through its other subsidiary.
    Curious....if you are having a set of wheels built on the AL33...….why don't you just have the Builder supply their preferred rim tape? That's what I did when I ordered all my parts from BHS and the tape I suggested was what Brandon, the owner, of BHS recommended I use.
    Sep 2007
    Quote Originally Posted by Notvintage View Post
    I'm not trying to answer for him, but tubeless tape is pretty much like a heavy packing tape in thickness. Two layers would still be thinner than something like Velox. I just started using it on my last two wheels and don't think I'd ever go back to Velox.
    I'm not suggesting packing tape, just used it at an example.
    changingleaf
    Aug 2009
    All tubeless tape is thin relative to rim strips or velox.
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    ^^^Absolutely this.^^^
    Why would you need 2 layers if you're using tubes? I use 1 layer for running tubes and never any problems.
    "If someone needs 200 rolls of toilet paper for a 14-day quarantine, they probably should have made a doctor's appointment way before the COVID-19 outbreak." -- Unknown
    "With
    -- DCGriz, RBR.
    changingleaf
    Aug 2009
    1 layer of most tubeless tapes is probably fine with tube.
    Reputation: smokva's Avatar
    Jul 2004
    One layer can be too thin and pressure can cut off tape on the spoke hole....happened to me once with 1 layer of dtswiss tape on dtswiss R460 rim running tubeless setup.
    Sent from my SM-G960F using Tapatalk
    Ante Smokrovic
    2009 De Rosa Neo Pro - Fedaia, Giau, Pordoi, Sella, Gardena, Campalongo, Falzarego, Valparola, San Pellegrino, Valles, Staulanza, Vršič, Mangart, Furcia...
    2003 De Rosa Team - Stelvio, Gavia, Mortirolo, Bonette, Agnel, Izoard, Fedaia, Giau, Pordoi, San Pellegrino, Staulanza, Manghen, Vršič, Učka, Mangart, Biokovo, Eisentalhöhe, Schonfeld, Schiestelscharte, Flattnitz...
    Banned Sock Puppet
    May 2014
    Quote Originally Posted by smokva View Post
    I said one layer is enough WHEN USING TUBES. i have never had the pressure from a tube punch through a single layer of Stan's tape into a spoke hole. Don't know about DT Swiss tape as I've never used theirs.
    "With
    -- DCGriz, RBR.
    Nov 2002
    What's the difference? Tubes or no tubes, same pressure being applied to the rim strip. I had a Rox rim strip blow through once. 2 layers of Stan's is prudent, in my opinion.
    Sent from my iPhone using Tapatalk Pro
    yeah I'm pretty sure he know that. Either way what he said is the answer. But who cares really. If two layers is too expensive or adds to much weight for you then have at it but I don't really see any reason not to be cautious and go around twice.
    Banned Sock Puppet
    May 2014
    No Jay, I'm not cheap nor am I a weight weenie. The only reason I go around only once is the same reason I don't use Velox anymore - I want to maximize the amount of space between rim and tire in order to make mounting and dismounting tires less of a pain. If I'm going to use 2 strips of Stan's, I may as well just use Velox and be done with it as it's easier to install in the first place.
    "With
    -- DCGriz, RBR.
    Sep 2007
    I'm willing to bet that most are pumping tubed tires to higher pressures than those running tubeless. And if I'm correct, there's a better chance of a tubed tire blowing thru the tape than the tubeless.
    Dec 2011
    We use 2 wraps of Stan's-equivalent tape whether for tubes or tubeless in all road/gravel wheels. In most cases we have no idea if the customer plans to use tubes or not, and we wouldn't modify it in any case. For mtb, we use one.
    2 wraps of tubeless tape is still WAY thinner than Velox - I'd guess 2 wraps is about 1/5th of 1/4th the thickness of Velox. Mounting difficulty is not increased with 2 wraps.
    In my own wheels or observing wheels that come back for crash replacement or other work, the tape at the spoke holes is always indented. Is two wraps the difference between problem and not? Don't know, don't care - we use two.
    I AM cheap, and if I felt that the extra material and time of 2 wraps was a waste I would absolutely not do it.
    Jul 2004
    As others have already said... pressure is pressure, doesn't matter tube or tubeless. I don't believe sealant can do some chemical reaction to weaken the tape.
    Anyway, one layer is too thin for race bike tyre pressure of 7-9 bar.
    Ante Smokrovic
    Banned Sock Puppet
    May 2014
    7-9 bars is 100-130 PSI. Unless you are over 100kg, that is way too much pressure.
    "With
    -- DCGriz, RBR.
    Jul 2004
    I'm 100kg when light, 120 kg currently
    I would never leave house with 25 mm tires on wide rims below 8 bars (115 PSI)...everything else is snakebite prooved. When I was riding 23 mm tires on narrow rims I had to go to 9,5 bars.
    Ante Smokrovic
  1. Rim Width - Tire Width Questions
    By littlepitboy in forum Wheels and Tires
    Last Post: 09-25-2014, 05:35 PM
  2. Rim tape width
    By sheepherder in forum Wheels and Tires
    Last Post: 07-10-2014, 12:51 PM
  3. what width rim tape?
    By [email protected] in forum Wheels and Tires
    Last Post: 07-05-2014, 01:27 PM
  4. Tire width vs. rim width
    By zpl in forum Commuting, Touring and Ride Reports
    Last Post: 08-19-2008, 07:22 AM
  5. Newbie Question: Tire Width vs. Rim width???
    By scotthunt1 in forum Cyclocross
    Last Post: 09-04-2005, 11:08 PM
