Results 1 to 22 of 22
    Nov 2006
    Road tires moving to even sizes reason?
    I noticed Bontrager and Specialized road tires are now 24 and 26x700c instead of previous 23 and 25’s
    Does anyone know why they changed?
    Change just to change?
    RC
    What the what???
    Jul 2009
    Maybe they're finally getting around to accurately measuring them.
    The Law of Headwinds states: If the ride out is easy... wait.
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    Quote Originally Posted by Opus51569 View Post
    Especially with wider-format rims making hitherto tire sizes even more of a wild guess.
    Sep 2011
    I really don't like the Specialized 26mm Turbo. They're simply too wide on a HED Belgium Plus. 25mm wide tire on 25mm wide rim is my cut off point. Anything wider feels sluggish
    changingleaf
    Aug 2009
    There's a trend for wider tires. The sizing is relative and somewhat arbitrary though, just like clothing sizes can be. I have a set of the 26mm Specialzed Turbo tires on Boyd Altamont rims and they measure 28.5mm wide. These rims are almost 20mm wide on the inside. The same tires measure about 27 on Reynolds Assault rims with a 17mm inner width. They are probably down to 26mm wide on 15mm inner width rims.
    On the Altamont rims with the tires perfectly centered they barely fit in the frame of a 2016 Cannondale Supersix.
    Note, 25mm Schwalbe pro one tires don't fit in the Cannondale and measure just over 29mm with the Altmaont rims.
    So these 25mm Schwalbe tires are actually wider than the 26mm Specialized tires.
    gazing from the shadows
    Jan 2003
    Quote Originally Posted by changingleaf View Post
    Yep. Somewhat arbitrary is a good way to put it.
    So it seems now they round up instead of down, since people are more likely to look for bigger rather than smaller (lighter) tires.
    There is data on the site on this, btw:
    http://forums.roadbikereview.com/whe...ad-363087.html Table in this one.
    http://forums.roadbikereview.com/whe...-306276-2.html No table, but some numbers.
    I am sure there are others out there as well, RBR and otherwise.
    'brifter' is a lame word.
    That's quite a generalization.
    For the OP: Bontrager is making their TLR tires in 24 and 26mm, the regularu clinchers are still 23 and 25mm. I've yet to mount a 25mm clincher and a 26mm TLR on the same wheel but I'm betting they're the same size.
    I work for some bike racers
    and a bunch of skateboards
    Nov 2006
    I purchased an old Bontrager AW2 in 25 while some new tires were in 24 and 26. The funny thing was the old stock 25 had a smaller profile then previous AW2 25’s. I know this because the previous AW2 would barely clear my 07 Buenos Aires stays at the brakes. They must have started making 24’s.
    BTW cx do you believe in the “aero wings” to reduce drag on these tires? I fall for marketing .
    RC
    Russian Troll Farmer
    Sep 2016
    I'm betting it's because a lot of older 'racing' frames are quite tight, and people need the in-between sizes. I'd love to try a 25 on my old Cannondale, but unfortunately, 24's are the widest that will fit.
    "L'enfer, c'est les autres"
    Dec 2006
    Somebody try and convince me the difference between 23 and 25mm tires is significant enough to be of real value. I think it's not even worth considering.
    If manufacturers offered 3mm size choices, then I'd take note.
    Quote Originally Posted by RoadCube View Post
    RC
    If the 'wings' had a big effect everyone would do them.
    Feb 2002
    Quote Originally Posted by Peter P. View Post
    So you think that being able to drop your tire pressure 10 psi is meaningless for comfort, traction, and tire wear? Most would disagree.
    I definitely feel there's a real difference.
    I'm not trying to convince you of anything but if you think there wouldn't be a difference then you should have nothing to lose by trying 25 yourself so why not find out for yourself instead of guessing.
    If they feel the same as you speculate, nothing lost there as same is same.
    changingleaf
    Aug 2009
    Well 2mm is certainly more than the flex between different wheels.
    Anyway if 2mm is not enough, then go to 28mm or if it doesn't matter then why not use 20mm for that matter.
    Sep 2011
    I'm going with the Unobtainium tire in size 24.5mm front for aero and 25.5mm rear for longetivity.
    Dec 2006
    I don't feel 2mm is significant enough of a size increase to exercise or gain the benefits you suggest.
    Dec 2006
    I did that many years ago with Micheline Hi-lite tires. Their advertised 23mm tire actually measured 19 or 20mm, I forget what I measured. All I know is I kept getting pinch flats at 100psi. for my 130lbs. and it wasn't worth the harsh ride of pumping them up harder to avoid the pinch flats.
    I DO intend to try 25mm tires when my current tires wear out.
    Jan 2003
    I love it when people doubt Kerry Irons.
    The issue is not width, it is volume. 2mm different width between 23s and 25s yields an 18% greater volume.
    Is 18% significant enough in your eyes?
    Feb 2010
    I'm way late here, but this is just an odd post.
    You say that 2mm is not worth considering, but then say that 3mm is worth taking note in a thread that talks about 26mm tires, which is 3mm off from 23mm. So are you taking note?
    I know math can be hard, but tires dont come in a straight line. The volume difference is significant, as has been pointed out.
    I can't try and convince you of anything. I can, however, try *to* convince you of something.
    Jul 2012
    How about that. My Continental 700x25 are 28mm when inflated on 25mm wheels. They feel so good on rough roads and even better on the smoother roads.
    Cleavage Of The Tetons
    Reputation: rideit's Avatar
    Feb 2005
    This is known in common parlance as 'splitting hairs'. Kind of.
    Reputation: GlobalGuy's Avatar
    Jun 2015
    Common sense and science has very slowly been overcoming traditional nonsense in cycling when it comes to road bike tires. The fact is that more often than not wider tires are better. They are faster, better handling and give a softer ride.
  1. European Shoe Sizes=U.S. Shoe Sizes
    By strohman in forum General Cycling Discussion
    Last Post: 02-23-2014, 06:52 PM
  2. Canari sizes vs Castelli sizes?
    By dougclaysmith in forum General Cycling Discussion
    Last Post: 01-14-2013, 07:51 PM
  3. Any real reason to even have the "hybrid" display mode?
    By robc in wi in forum SiteFeedback/Issues
    Last Post: 04-28-2012, 06:33 PM
  4. Are cycling shoe sizes the same as tennis shoe sizes?
    By Morisato in forum General Cycling Discussion
    Last Post: 05-22-2011, 07:40 PM
  5. Replies: 11
    Last Post: 03-24-2008, 02:27 PM
