• 03-28-2019
    farva
    3 Attachment(s)
    Rolf Vector Comp freehub help
    I've got a set of circa 2000 blue Rolf Vector comps that I want use on a a Vintage Olmo restoration. These wheels look sweet against its blue ano cranks and stem so I really want to use them. Trouble is these vectors have shimano 10s freehub and campy version is not available. Bike is Italian so drivetrain has to be campy (Mirage 9 spd). Any idea's on how to make this work? Who actually makes these hubs? AM classic and other brand conversion cassettes seem to be a thing of the past. ThanksAttachment 324883
    Attachment 324884Attachment 324885
  • 03-28-2019
    cxwrench
    Good luck with that.
  • 03-28-2019
    frdfandc
    Rolf Wheels is not the same company today as it was 20 years ago.
    https://rolfprima.com/pages/older-rolf-wheels
    Cut your losses and get a modern day wheelset. Your not going to find a Campy freehub.
  • 03-28-2019
    jpz
    Many moons ago, I had Campy record 10 speed & several sets of wheels, I had a Shimano set that I replaced all the Shimano cassette spacers w/ Campy 9 speed spacers.
    It worked great. When setting it up, center the derailleur on the 5th cog (with shifter in 5th) I was told it wouldnt work, worked great, gave me no troubles. The Shimano 9 speed cogs actually worked better than Camps 9 speed cogs .
  • 03-29-2019
    frdfandc
  • 03-29-2019
    farva
    those Primato cassettes appear to be either campy or shimano, not a conversion cassette . Thanks for the links though.
  • 03-29-2019
    farva
    thank you. Seems like this is the only option that will work. Cheers
  • 03-29-2019
    Bremerradkurier
    Local to me Craigslist has a set of Rolf's for sale with a Campagnolo freehub that's been up quite a while-not sure if older 9 speed used the sample splines.
    https://washingtondc.craigslist.org/...842847490.html
  • 03-29-2019
    farva
    thanks those look decent. Think I'm gonna try the homemade cassette stack first. Apparently the version I have didn't even have a campy freehub option so not sure I'd be able to swap freehubs with those CL wheels.
  • 04-24-2019
    farva
    2 Attachment(s)
    got it all worked out. SRAM cogs with campy 9s spacers. Was only able to fit 8 cogs with @ 9s spacing but that's plenty for this retro rig. Shift quality not bad at all. Thanks for the help (except mr cxtool)
    Attachment 325000
    Attachment 325000
  • 04-24-2019
    cxwrench
    Quote:
    Attachment 325000
    Attachment 325000
    My heart is broken now...that really hurt. :rolleyes:
