Rolf Vector Comp freehub help
Results 1 to 11 of 11
    Jun 2005
    I've got a set of circa 2000 blue Rolf Vector comps that I want use on a a Vintage Olmo restoration. These wheels look sweet against its blue ano cranks and stem so I really want to use them. Trouble is these vectors have shimano 10s freehub and campy version is not available. Bike is Italian so drivetrain has to be campy (Mirage 9 spd). Any idea's on how to make this work? Who actually makes these hubs? AM classic and other brand conversion cassettes seem to be a thing of the past. ThanksIMG_0425.jpg
    'brifter' is f'ing stupid
    Good luck with that.
    #promechaniclife
    Rub it............
    Reputation: frdfandc's Avatar
    Nov 2007
    Rolf Wheels is not the same company today as it was 20 years ago.
    https://rolfprima.com/pages/older-rolf-wheels
    Cut your losses and get a modern day wheelset. Your not going to find a Campy freehub.
    You can't fix stupid.
    Quote Originally Posted by JoeDaddio
    jpz
    jpz is offline
    Jan 2007
    Many moons ago, I had Campy record 10 speed & several sets of wheels, I had a Shimano set that I replaced all the Shimano cassette spacers w/ Campy 9 speed spacers.
    It worked great. When setting it up, center the derailleur on the 5th cog (with shifter in 5th) I was told it wouldnt work, worked great, gave me no troubles. The Shimano 9 speed cogs actually worked better than Camps 9 speed cogs .
    Rub it............
    Nov 2007
    Jun 2005
    those Primato cassettes appear to be either campy or shimano, not a conversion cassette . Thanks for the links though.
    Jun 2005
    Quote Originally Posted by jpz View Post
    thank you. Seems like this is the only option that will work. Cheers
    May 2012
    Local to me Craigslist has a set of Rolf's for sale with a Campagnolo freehub that's been up quite a while-not sure if older 9 speed used the sample splines.
    https://washingtondc.craigslist.org/...842847490.html
    Jun 2005
    Quote Originally Posted by Bremerradkurier View Post
    thanks those look decent. Think I'm gonna try the homemade cassette stack first. Apparently the version I have didn't even have a campy freehub option so not sure I'd be able to swap freehubs with those CL wheels.
    Jun 2005
    got it all worked out. SRAM cogs with campy 9s spacers. Was only able to fit 8 cogs with @ 9s spacing but that's plenty for this retro rig. Shift quality not bad at all. Thanks for the help (except mr cxtool)
    Quote Originally Posted by farva View Post
    My heart is broken now...that really hurt.
    #promechaniclife
  1. Rolf Vector Comp Freehub
    By SweatBlood in forum Components, Wrenching
    Last Post: 08-21-2008, 12:08 PM
  2. Looking for a Rolf Vector Pro Freehub Body
    By Fett in forum Wheels and Tires
    Last Post: 02-28-2006, 04:55 PM
  3. Rolf Vector Pro Vs. Vector Comp Wheels?????
    By bowler1 in forum General Cycling Discussion
    Last Post: 09-05-2005, 11:38 AM
  4. Rolf Vector Comp hub service....
    By 10kman in forum Components, Wrenching
    Last Post: 06-09-2004, 07:13 AM
