Sapim Cx Super spokes
Results 1 to 22 of 22
    Aug 2017
    I'm planning to build a new wheels sets, and I'm interested in your opinion about the new Sapim spokes, the Cx Super.
    Assuming 3 hypothetical wheels sets, all with the same rims (carbon rim 38-45mm depth) and the same hubs, but one sets with Sapim Cx Ray, one with Sapim Sprint and the last one with the new Sapim Cx Superx, what difference will be between the wheels in terms of lateral stiffness, comfort ecc ecc ?
    Thanks to all for the advice.
    'brifter' is a lame word.
    I'd go with CX-Ray, unless you're over say...225lbs and/or a guy that kills wheels. In that case I'd go CX-Super, the extra material in the middle of the spokes will help build stronger wheels. Possibly a little stiffer in lateral flexibility as well.
    I work for some bike racers
    and a bunch of skateboards
    Schuylkill Trail Bum
    Reputation: SPlKE's Avatar
    Sep 2007
    This level of wrench expertise is one of the few things that keeps me coming back to RBR forums.
    As always, thanks cx, ya crabby bastich.
    Quote Originally Posted by SPlKE View Post
    Lucky for you you're one of my favorites
    Aug 2017
    Thank you very much.
    hem, yes I'm heavy, 180lbs, and my Dura Ace C24 rear wheel it's gone after 20.000km.
    I'm plannig to build a new wheelset, with Yuniper hubs and Fastop Bike carbon rims, maybe 38mm depth front rim and 43mm depth the rear rim.
    I'm uncertain about the spokes, Super Cx are very expensive but probably it's the best choice.
    0 Links
    180lbs is not heavy, it's average in the US. If you can't justify spending the $$$ on the CX Super then get a good quality butted round spoke. DT Swiss Comp is a great choice, I'm sure the Sapim spokes will work fine as well.
    changingleaf
    Aug 2009
    The Sprint has the most material in the middle.
    There is also a CX-sprint available.
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    Quote Originally Posted by Rone69 View Post
    0 Links
    Can I ask what was the reason for the demise of these wheels?
    As CX said, 180 is not heavy. 20,000 km is about 12,500 miles which isn't bad for a low-spoke wheelset which IIRC, those wheels have a 16/20 spoke count.
    If you really want a stronger, stiffer wheel, go with more spokes. I think 24/28 should be minimum and personally, I like 24/32.
    If you are concerned with spokes breaking, keep in mind that spokes almost always break at either the nipple or the j-bend. So getting spokes with a thicker center will not prevent spoke breakage. Though thicker spokes will make wheel building easier because they twist less.
    Aug 2017
    In the first post, I've mentioned 3 kind of Sapim spokes: CxRay, Cx Sprint an Super Cx.
    Banned Sock Puppet
    May 2014
    Personally, of these 3, I would go with the CX Sprints.
    Not at all would be my guess. I definitely don't notice any difference between different spokes on otherwise identical wheels.
    Oct 2013
    I built some wheels with Sapin Xray I think, some broke. I used DT swiss on the rebuild and never had a problem after that. 175lbs.
    BANNED
    Aug 2017
    In you opinion, the difference will be only the wheels weight and more or less money in the pocket ??
    Aug 2017
    Please can you explane the reason of your choice?
    Aug 2017
    Wich model of Dtswiss spokes?
    The only difference a rider can perceive, yes, that has been my my experience with several different spokes on otherwise identical wheels.
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    Yup...although consult your wheel builder and rim OEM--some spokes start getting too strong for usage in some carbon rims.
    With carbon rims....they are very stiff and very stiff/straight without being laced....you're not going to feel a difference between spokes.
    pmf
    pmf is offline
    I weigh around 200 lbs and have several sets of wheels with cxray spokes 24F/28R. They all have White Industries T11 hubs. I've been riding them for years and never even had to true them.
    Banned Sock Puppet
    May 2014
    I don't feel the others are worth the extra cost, not to mention spokes that are very thin are a PITA to build with.
    Aug 2017
    Tanks to all for the advices.
    changingleaf
    Aug 2009
    You showed the specs for the round Sprint in your first post, which is not the same as the bladed CX-sprint.
    Any bladed spokes make truing a wheel easier if you have the bladed spoke holder. The bladed spoke holder is different for the Sprint and the Ray spokes.
    All of these spokes will last a very long time on a properly built wheel. The thinner spokes will be slightly more prone to damage and breakage from debris on the trail. I think the choice comes down to how much do you want to save weight and how much do you want to spend.
    Banned Sock Puppet
    May 2014
    Quote Originally Posted by changingleaf View Post
    Yes, it is true that bladed spokes help with building as twist is easily seen and corrected.
    In the end, IMHO, I don't think the minuscule weight savings is worth the extra cost of ultra skinny spokes in general.
  1. Spokes: DT Revolution 14/17 vs Sapim CX Ray
    By MIN in PDX in forum Wheels and Tires
    Last Post: 12-24-2007, 03:07 PM
  2. Where to get Sapim CX Ray spokes
    By Snopro440 in forum Wheels and Tires
    Last Post: 11-24-2007, 04:45 AM
  3. Any Experience with Sapim CX Ray Spokes?
    By O-Man in forum Wheels and Tires
    Last Post: 11-10-2007, 04:05 AM
  4. should I get the sapim cx-spokes
    By ishmael in forum General Cycling Discussion
    Last Post: 01-13-2006, 08:29 AM
  5. sapim CX-ray spokes
    By hambinator in forum Wheels and Tires
    Last Post: 12-03-2005, 12:06 PM
