So I guess this wheel is done
Results 1 to 16 of 16
    Reputation: Dr_John's Avatar
    Oct 2005
    I just discovered this on my Shimano WH-R600 wheel set's rear rim. They have exactly 10,000 miles on them. I've had them for two years, I'm guessing they're out of warranty.
    Reputation: nrspeed's Avatar
    Jan 2005
    Put that wheel to bed and celebrate its good life.
    Banned forever.....or not
    Aug 2002
    A rebuild will be cheaper than a new wheel.
    Dogbert.
    I>U
    Oct 2005
    Thanks. And of course I just re-did the hubs. This might seem like a stupid question - I understand why I don't want to use it on the road, but I don't see that there'd be any real danger using it on a trainer?
    Feb 2006
    I know someone here who breaks his Shimano rear rim every year, and Shimano has been really good about giving him a new wheel... worth a try I think.
    Big is relative
    Reputation: bigbill's Avatar
    Feb 2005
    Quote Originally Posted by Dr_John
    You could use it on the trainer as long as it is relatively true. A crack like that could be caused by stress and the crack itself has probably relieved the stress. It won't get better though. Better to have it fail while clamped in a trainer. What kind of trainer? I have an Elite that still puts alot of weight on the rear wheel.
    I would try the shimano route to see if you can get a new rim/wheel.
    Retired sailor
    Reputation: android's Avatar
    Nov 2007
    Agree with Grumpy. Have it rebuild with a better rim, the reviews seem to indicate these crack a lot.
    Resident Curmudgeon
    Nov 2005
    I agree. No need to waste money buying a whole new wheel. Just get a rim.
    Jan 2006
    I don't think you can expect Shimano to replace it after 2 years/10,000 miles on it! Sounds like you got good value for money, especially because this particular wheelset is known to sometimes fail exactly as described in your picture.
    Sep 2004
    warranty info
    Mar 2003
    Sounds like a candidate for some great neuvations. LOL.
    Reputation: VinPaysDoc's Avatar
    May 2005
    It won't hurt to ask
    Dr. John,
    It wouldn't hurt to ask the folks you bought it from if it is still under warranty. If you purchased it from the LBS they might well take care of it for you.
    Heck, I purchased a 2004 Trek 5900 and the LBS has replaced the Bonti Race X Lites for me now twice. The first one broke the hub and they sent me two new wheels. This second set had several areas on the rear rim beginning to crack and they're replacing it.
    It never hurts to ask.
    Greg
    Oh hai there
    Reputation: de.abeja's Avatar
    Aug 2006
    JB weld it!
    At least ask shimano for some help, maybe a discount/free rim,whole wheel could come of it.
    Mar 2007
    Quick question, Shimano has the nipples at the hub, can you use any normal rim or are there special ones with special straight spokes? Has anybody built a wheel with inverted nipples?
    Quote Originally Posted by threesportsinone
    no, rims for spokes at the hubs have smaller holes.
    Oct 2005
    Thanks for all the responses.
    For the majority of the type of riding I'm doing, they've been great. I've never busted a spoke, or had to have them trued. I re-packed the hubs not because they needed to be, but I had accidentally loosened the cones, so I figured I'd go ahead and do it (I've never done it before). They still spin and feel great. They certainly haven't been abused, and I'm a pretty light rider (140-145 lbs).
    It's still true. I have no idea how long it's been like that, but I would suspect not long. My intent is to use it now on my trainer (CycleOps 2 fluid).
    These were the original wheels that came on my 2006 Roubaix Expert, so it's easy enough to run it by the dealer I bought the bike from. The warranty on the bike from Specialized and Ultegra-level stuff from Shimano is one year, so I'm not expecting much. As hockinsk mentions, this was a known problem with either the similar 105-level wheels or the previous year's version of this level wheel (don't remember which), but I thought I had heard that the issue had been resolved on this set. Maybe Shimano will come through.
    Again, thanks.
