Spare tubes when running tubeless road tires? - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 61
  1. #26
    'brifter' is a lame word.
    FWIW, in 40 years of driving (and only 1 car that required inner tubes), I have never seen a tubeless tire that didn't need bead sealant to mount. I once actually mounted a tire onto a rim dry, and that thing leaked like a MF for the next week, when i had it dismounted, and had some bead sealant put on.
    Which is different from tubeless bicycle tire sealant. It performs a different job.
    I work for some bike racers
    and a bunch of skateboards
  2. #27
    Sep 2016
    .I just got a set of GP5000TL. Man those things seated like butter. I had used my compressor, but pretty sure I could've done it with a floor pump.
    I bought GP5000 before I knew about sealant or air compressors/tubeless pumps. They seated on my wheels with no problem using the pump in the usual manner. Negligible air loss overnight.
  3. #28
    changingleaf
    Aug 2009
    It's always a good idea to bring a tube even though I usually don't. In about 12 years of riding tubeless road tires I've had two cuts in the tire (sidewall) that didn't seal or at least didn't hold enough air to get home, so I had to install a tube.
  4. #29
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    Quote Originally Posted by changingleaf View Post
    IMHO, not carrying a tube is one of those things like not keeping an eye on the gas gauge in your car. The resultant situation is TOTALLY PREVENTABLE.
  5. #30
    Nov 2002
    I pulled a thorn out of my gravel tire in the garage. Sealant squirted out. Wouldn't seal. Tire pressure was about 50 psi. Garage temperature was about 45-50 degrees F. Using Orange Seal Endurance. Put some fresh sealant in and it sealed. Why wouldn't it seal? Temperature too low? There was plenty of sealant in the tire, as there was a sizable puddle of it on the floor.
  6. #31
    Reputation: upstateSC-rider's Avatar
    Aug 2004
    I've had good luck turning the wheel so the puncture is on the bottom while sloshing it around a little, others do the same while tapping the wheel on ground also.
    Either way, why tempt fate by not carrying a tube?
    In reference to the Assault on Mt Mitchell...
    Quote Originally Posted by merckx56
    The easier solution is to find a biker bar in Spartanburg the night before, go in and pick a fight. The ass-whipping you'll get will be far less painful than the one Mitchell will give you the next day!
  7. #32
    Sep 2011
    I've never seen anything like that. I've seen a few roadside repairs and tires always came off just fine.
    Any of my wheels tires changes are done easily by hand. I can usually get them off without levers.
    You've never seen Reynolds rims have you
  8. #33
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    Nope. But I've seen many others that come off fine.
  9. #34
    Nov 2002
    Quote Originally Posted by upstateSC-rider View Post
    Yeah, did that. Still didn't seal. The sealant must not work as well at lower temperatures, although I would think 50 degrees isn't that low. I always carry a tube. Also, I recommended never pulling out a thorn when out in the road, in case the sealant doesn't work.
  10. #35
    tlg
    tlg is offline
    May 2011
    I've been using Orange Seal Endurance for years. I use it year round down into the 20°'s. Never had a hole not seal (never had it spray either).
    I agree, I wouldn't pull a thorn.
  11. #36
    Feb 2002
    The fact that it worked when you put new sealant in suggests that the existing sealant had separated, and so the thin liquid was what was coming out of the tire. If anything, sealant should work better in cold weather because it will get thicker with dropping temperature. Had the bike been sitting for a while, such that the tire wasn't spinning and therefore the sealant wasn't being sloshed and mixed?
  12. #37
    Nov 2002
    Yeah it was sitting. Just before a ride. Also, I'm not shaking the bottle enough before putting sealant in the tire. Thus, it's thinner than it should be.
    Sent from my iPhone using Tapatalk Pro
  13. #38
    tlg
    tlg is offline
    May 2011
    Yikes
    Sealant is a mixture of rubber particles suspended in liquid. If all your putting in your tire is the liquid it ain't gonna work.
  14. #39
    Nov 2002
    Yikes
    I gave the bottle a few shakes. The problem is if you shake the bottle too much, OS foams up and then how do you know how much you've poured out in a cup to inject or pour in the tire? I guess I'm going to have to figure out how much it weighs per fl. oz. and weigh it beforehand.
    Rubber particles? You sure? I know there's some glitter in there.
  15. #40
    Jul 2012
    OP, just be sure you have Uber or Lyft app on your phone.
  16. #41
    Cleavage Of The Tetons
    Reputation: rideit's Avatar
    Feb 2005
    You are overthinking it. Just shake it up and and pour a decent amount in there.
  17. #42
    Reputation: Srode's Avatar
    Aug 2012
    2 things to do - use the dipstick to see how deep it is in your tire after the foam dissipates -
    Or you can do like I do and:
    1. Shake it up
    2. Put the filler tube cap and tube on the bottle
    3. Invert the bottle and squeeze the liquid off the bottom into another bottle.
    4. Move the filler cap to that bottle that won't have any foam in it, and put the desired quantity in your tire using the levels on that bottle to gauge it.
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    BH G7 Disc
    Trek Crockett
  18. #43
    Banned Sock Puppet
    May 2014
    Quote Originally Posted by Methodical View Post
    A spare tube is a lot cheaper than an Uber or Lyft ride!
  19. #44
    Nov 2002
    1. Shake it up
    I use the large 32 oz bottles, so that won't work for me.
  20. #45
    Aug 2012
    I use 32 oz and shake it up and then put it into a smaller 4oz bottle with the dispenser straw like I described. That cap fits on all their bottles.
    Gravel Rocks
    Trek Domane
    BH G7 Disc
    Trek Crockett
  21. #46
    Feb 2002
    1. Shake it up
    And here we have a perfect summary of why many of us old-timers don't think that tubeless is the solution to anything, let alone an improvement.
  22. #47
    Reputation: Wetworks's Avatar
    Aug 2012
    Because it's too involved or complicated?
    I'm a new cyclist (10 years) but an older guy (50). I made the switch because of a trip to Utah and worry over goatheads. I've since decided to convert all of my bikes. Why? The ride is much better, and any apprehension over a flat has greatly reduced. Initial setup for one of the bikes was frustrating if I'm being honest, but I'm all in now.
  23. #48
    Aug 2012
    Not all old timers, I'm 63 and like tubeless - just sayin.
    Easier than changing a shifter cable for those still using them.
    Gravel Rocks
    Trek Domane
    BH G7 Disc
    Trek Crockett
  24. #49
    Quote Originally Posted by Wetworks View Post
    I see it the other way around.
    I virtually never see posts from people with issues changing a regular clincher on a regular clincher rim. But valid or not I've seen hundreds of reports of people having some sort of issue or confusion changing out tubeless.
    I've only seen a tubless flat repair on the road twice both times when I stopped to help someone. Both times it looked like Ron Jeremy had recently made a movie using the guy and his bike and it was a freaking nightmare getting the tire off an back on with a tube in it.
    So from my angle if anything is going to cause apprehension it's tubeless. I know for a fact I can deal with clinchers with my eyes closed, so to speak. I haven't seen a lot to give me the same confidence about tubeless. I understand that goatheads might call for something I don't need but my take on tubeless is it's a case of a pound of prevention being worth an ounce of cure.
  25. #50
    Schuylkill Trail Bum
    Reputation: SPlKE's Avatar
    Sep 2007
    You mean a Brifter cable, don't you?
  1. Running (older) Mavic SUP tires tubeless...am I gonna die?
    By rideit in forum Components, Wrenching
    Last Post: 09-23-2018, 11:03 AM
  2. Tubes, Tubes, Tubes, there is a difference
    By Mr645 in forum Wheels and Tires
    Last Post: 10-06-2014, 08:26 PM
  3. Replies: 2
    Last Post: 10-14-2013, 06:16 AM
  4. Running regular tires on tubeless wheels
    By trener1 in forum Wheels and Tires
    Last Post: 01-15-2013, 07:13 AM
  5. Keep spare tubes spare?
    By Snowonder in forum General Cycling Discussion
    Last Post: 04-04-2011, 06:57 PM
