Specialized bike tubes
Results 1 to 3 of 3
    Apr 2013
    Any quality difference between Bontrager and Specialized bike tubes? I had a failure by the valve on a Specialized tube 60 miles into a 100 mile ride. Same pressure I always use 80 PSI. Might just be bad luck but I've never had this happen on a newish bike tube. Can't be from braking heat as the bike is disc.
    I've been riding on Bontrager tubes for years so thought I'd ask. I'm assuming its just a fluke unless I hear otherwise
    'brifter' is a lame word.
    Fluke. I wouldn't be surprised if 99% of the tubes on the planet were made in maybe 2 factories.
    I work for some bike racers
    and a bunch of skateboards
    [REDACTED]
    Reputation: Lombard's Avatar
    May 2014
    I would say a fluke. If a tube is going to fail for a defect, around the valve is almost always where it will be.
  1. Tubes, Tubes, Tubes, there is a difference
    By Mr645 in forum Wheels and Tires
    Last Post: 10-06-2014, 08:26 PM
  2. Replies: 23
    Last Post: 05-31-2014, 07:57 PM
  3. Are all tubes created equal? (Long Valve Tubes)
    By r_mutt in forum Wheels and Tires
    Last Post: 01-30-2008, 06:15 PM
  4. Specialized thorn resistant racing road tubes
    By Jett in forum Wheels and Tires
    Last Post: 10-17-2005, 02:43 AM
  5. Of tubes more tubes
    By Enviro Mental in forum General Cycling Discussion
    Last Post: 07-08-2005, 10:15 AM
