Spoke Length
Results 1 to 6 of 6
Thread: Spoke Length
    Feb 2013
    Spoke Length
    Need to replace a few spokes in a Giant SLR1 wheel. Spoke length is 287mm. Seems like normally stocked spokes are either 286 or 288. What would be the best length to get?
    changingleaf
    Aug 2009
    Take a look at the rest of the nipples and see if the spokes are threaded all the way to the top of the nipple or above. If so, then get the 286. If the spokes are 1mm below the top of the nipples then get the 288.
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    Can I ask why you are replacing a few spokes?
    Quote Originally Posted by sasquatch16 View Post
    Make sure you measure the width. I did some work on my buddies SLR rear wheel that was a 2:1 lacing, 21 spoke wheel. It had Sapim CX Sprint on right side Pulling and CX Rays on right side NON pulling
    Feb 2013
    Friend of mines wheel. He had some spokes that kept getting loose and a few seized nipples. Will probably end up replacing all spokes and nipples. Specs. in Giants literature say 287 drive side and 291 non drive side. I will wait to actually measure once I take it apart. Will take note where existing spokes end in nipple befor taking apart.
    Banned Sock Puppet
    May 2014
    Good idea at this point. Only a matter of time before problems surface with other nipples. May as well re-lace the wheel.
    Specs. in Giants literature say 287 drive side and 291 non drive side. I will wait to actually measure once I take it apart. Will take note where existing spokes end in nipple before taking apart.
    ALWAYS do you own measurements. NEVER trust what is in manufacturer specs. I and others have found errors in manufacturer specs. You want to find this out BEFORE you lace the wheel, not AFTER.
  1. Why do spoke length calculators not ask about nipple length?
    By Waspinator in forum Wheels and Tires
    Last Post: 12-15-2017, 08:48 AM
  2. Stem length/rise - relative length?
    By SDizzle in forum Components, Wrenching
    Last Post: 05-09-2006, 07:53 PM
  3. Offset spoke hole rims: How to calculate spoke length?
    By Ohm_S.Ohm in forum Wheels and Tires
    Last Post: 02-15-2006, 07:53 AM
  4. relation between top tube length vs. stem length
    By NoMSG in forum General Cycling Discussion
    Last Post: 03-20-2004, 05:29 PM
  5. Stem Length, Top Tube Length Ratio
    By purple puma in forum Cyclocross
    Last Post: 02-25-2004, 08:02 AM
