Spokes in WH-7850 for 45mm deep Rims
Results 1 to 1 of 1
    Jan 2009
    Hi, I made dumb (impulsive) purchases and brought two Rovals rims not realizing the rear wheel usually do not have 20 holes. Then I made second dumb purchases, base on info from bikeforums*net (the dura ace 7850 have "regular straight pull spokes"), the WH-7850 hub - that make the guy in bike shop not twice happy - he can not fit in any spokes.
    Find out (see link below), the hub use278mm spokes long for C50 rims and I have 45mm rims. My question is, would mavic spokes from 45mm rims fit in WH-7850 (and of course which ones) or do You have any other "fitting" recommendation.
    And if not, would be a problem drilling 4 more holes (cross) in to rim? Thanks a lot guys for any edvice an sry for my english.
    https://si.shimano.com/pdfs/ev/EV-WH...CL-R-2851B.pdf
    Y-012 AB787 Spoke (278 mm)
  1. WH-7850-C24-TL vs WH-5850-SL
    By jamesm_95 in forum Wheels and Tires
    Last Post: 11-03-2010, 11:54 AM
  2. WH-7550 SL vs WH-7850-C24-CL
    By rcekstrom in forum Wheels and Tires
    Last Post: 11-03-2010, 04:14 AM
  3. shimano WH-7850-C24-TL and WH-RS60-C24-TL
    By dragon in forum Wheels and Tires
    Last Post: 09-25-2009, 07:48 AM
  4. Velocity coming out with 45mm deep rim?
    By Zen Cyclery in forum Wheels and Tires
    Last Post: 04-01-2009, 04:32 PM
  5. Shimano WH-6500/WH-7700 spokes
    By Sao in forum Components, Wrenching
    Last Post: 05-10-2007, 08:35 AM
