• 08-14-2019
    sasquatch16
    Stress Relieving with Bladed Spokes
    Do you still follow the practice of squeezing parallel pairs of spoke when the wheel is built with bladed spokes? is there a better way?
  • 08-14-2019
    cxwrench
    I definitely do that. I will also put the wheel on the ground and push on the rim, move it a bit, push on the rim...repeat. You can do it with the wheel oriented either vertically or horizontally, I think it's better horizontally. You can also make a 'stress relieving box' and then you'll gain a little consistency.
  • 08-14-2019
    sasquatch16
    Thanks. Wasn’t sure if it would hurt the spoke squeezing it across the wide area
  • 08-15-2019
    ergott
    Quote:
    Hurts the hands more, even with heavy gloves. Still my preferred method.
  • 08-15-2019
    changingleaf
    I squeeze through the wheel, squeezing the left and right sides together. I grab two spokes at each side where they are crossed and squeeze.
  • 08-15-2019
    mfdemicco
    Wheel Fanaytic recommends this method of stress relieving.
    https://uploads.tapatalk-cdn.com/201...63b64dc94f.jpg
  • 08-15-2019
    cxwrench
    I never really thought of that as 'stress relieving' but more of seating the heads of the spokes in the hub flange properly. I guess it does both. I would do this when the spokes were still relatively loose and then squeeze the spokes as tension is getting higher.
  • 08-16-2019
    Lombard
    Quote:
    This. You cannot hurt the spokes by squeezing them together with your hands unless they aren't yet up to tension. This a paltry compared to the stress on the spokes while riding the bike. Not to mention that the making of a spoke is a brutal process in itself.
    No, you won't hurt the spokes. Get the heaviest pair of gloves you can find.
  • 08-16-2019
    Lombard
    This is a good thing to do and Mike T. recommends something similar to this on his website. However, it is something to do additionally, not a substitute for squeezing spokes together.
  • 08-16-2019
    coachboyd
    We built this back in 2013 or so and the total cost was under 100 bucks. Air cylinder off ebay, steel beam from the scrap yard, wood that was laying around. It's been Mr. Reliable for years!
    https://www.youtube.com/watch?v=IyhnqgioBI4
  • 08-18-2019
    mfdemicco
