Stress Relieving with Bladed Spokes
Results 1 to 11 of 11
    Feb 2013
    Do you still follow the practice of squeezing parallel pairs of spoke when the wheel is built with bladed spokes? is there a better way?
    'brifter' is a lame word.
    I definitely do that. I will also put the wheel on the ground and push on the rim, move it a bit, push on the rim...repeat. You can do it with the wheel oriented either vertically or horizontally, I think it's better horizontally. You can also make a 'stress relieving box' and then you'll gain a little consistency.
    I work for some bike racers
    and a bunch of skateboards
    Feb 2013
    Thanks. Wasn’t sure if it would hurt the spoke squeezing it across the wide area
    wheelbuilder
    Reputation: ergott's Avatar
    Feb 2006
    Quote Originally Posted by sasquatch16 View Post
    Hurts the hands more, even with heavy gloves. Still my preferred method.
    changingleaf
    Aug 2009
    I squeeze through the wheel, squeezing the left and right sides together. I grab two spokes at each side where they are crossed and squeeze.
    Nov 2002
    Wheel Fanaytic recommends this method of stress relieving.
    I never really thought of that as 'stress relieving' but more of seating the heads of the spokes in the hub flange properly. I guess it does both. I would do this when the spokes were still relatively loose and then squeeze the spokes as tension is getting higher.
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    Quote Originally Posted by ergott View Post
    This. You cannot hurt the spokes by squeezing them together with your hands unless they aren't yet up to tension. This a paltry compared to the stress on the spokes while riding the bike. Not to mention that the making of a spoke is a brutal process in itself.
    No, you won't hurt the spokes. Get the heaviest pair of gloves you can find.
    Banned Sock Puppet
    May 2014
    This is a good thing to do and Mike T. recommends something similar to this on his website. However, it is something to do additionally, not a substitute for squeezing spokes together.
    Boyd Cycling owner
    Reputation: coachboyd's Avatar
    Jan 2008
    We built this back in 2013 or so and the total cost was under 100 bucks. Air cylinder off ebay, steel beam from the scrap yard, wood that was laying around. It's been Mr. Reliable for years!
    www.boydcycling.com Handcrafted Revolution
    Nov 2002
  1. The physics of properly stress relieving wheels?
    By TomH in forum Wheels and Tires
    Last Post: 12-08-2010, 07:16 PM
  2. stress relieving wheels?
    By Fixed in forum Wheels and Tires
    Last Post: 05-19-2009, 05:15 PM
  3. zipp wheels stress relieving
    By steel515 in forum Wheels and Tires
    Last Post: 07-12-2007, 12:05 PM
  4. Pain relieving gel - A+
    By innergel in forum The Lounge
    Last Post: 02-05-2007, 04:14 PM
  5. Bladed spokes and record hubs. Dremel?
    By mdvilla in forum Components, Wrenching
    Last Post: 04-05-2004, 09:42 PM
