Swapping wheels - rotor alignment so I don't have to adjust the caliper each time
Results 1 to 11 of 11
    Reputation: multirider's Avatar
    Nov 2007
    I purchased a second set of disc wheels for my disc braked bike. When I swap wheels, the rotors don't line up. The wheels (including hubs) are from two different manufacturers.
    I had two sets of wheels for a mountain bike previously, the LBS had some really thin shims that could be used under the rotor to get one set to line up with the other set.
    My new road bike has the Shimano Centerlock hubs. Both wheelsets are Centerlock, but the rotors don't line up quite the same and the thin shims for 6 bolt rotors wouldn't work.
    I'm reluctant to bend the rotors all the way around because that would undoubtedly result in wavy rotors. I'd hate to ruin one or more $70 rotors.
    Is there a way to get the rotors adjusted so that I can swap wheels without having to align the caliper each time?
    Dec 2011
    Nov 2007
    You have rocketed to the top of my Favorite People List. Thanks!
    Nov 2013
    Interesting... this challenges my, "One bike, multiple wheel sets" theory. I wonder how likely rotors are to line-up if you have multiple wheel sets that use the same hubs and discs. Hmm...
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    Quote Originally Posted by PoorInRichfield View Post
    I'm guessing if hubs and discs are the same, you shouldn't have a problem.
    I built two new wheelsets for my disc gravel bike in the last year. I used the same discs as on the OE wheelset, but I used Shimano R770 hubs vs. Formula hubs on the OE's. I have a very slight rub on my rear brake with the new wheels, but not the front.
    "With
    -- DCGriz, RBR.
    Dec 2011
    There's no need to have rotor rub, even with center locks. The shims linked above resolve to within .25mm repeatability among different wheels. Worst case (mechanical brakes and quick release axles) you should still be able to eliminate all rotor rub using shims. One bike and multiple sets of wheels is very much a valid thing.
    Nov 2016
    Quote Originally Posted by November Dave View Post
    They are not easy to find. Got mine from Boyd cycling.
    https://boydcycling.com/collections/...or-shim-4-pack
    Got em in 48hrs.
    Envoyé de mon iPhone en utilisant Tapatalk
    Dec 2011
    They're not that hard to find -https://novemberbicycles.com/collect...shim-pack-of-4 - signed, the guy who invented them.
    Nov 2016
    Interesting, we would to test the equations of the N+1 where N is the number of bike.
    New equation should be :
    N+1=2Wx2
    N= 2Wx2-1N
    N=2Wx2-1N
    N+1 Or (2Wx2-1N)+1 would apply
    Nov 2016
    Actually I just did the change and was planning to add spacer but ended up not needing it.
    Before doing so follow this procedure:
    1.Use the wheel with the disk point the most outward.
    2.Space the pad as far as possible on both side.
    3. Unscrew the break from the frame, just loose it.
    4. Hold the brake
    5. Screw back the brake to the frame
    6. Tighten/adjusting the pad back to the disk.
    7. Try the other wheel.
    Banned Sock Puppet
    May 2014
    Quote Originally Posted by Patb095 View Post
    N+1=2Wx2
    N= 2Wx2-1N
    N=2Wx2-1N
    Clever.
    "With
    -- DCGriz, RBR.
  1. Replies: 5
    Last Post: 04-18-2013, 07:16 PM
  2. Replies: 17
    Last Post: 05-18-2012, 07:03 PM
  3. Replies: 1
    Last Post: 05-17-2012, 01:55 PM
  4. How do I adjust my derailleur if only 2 gears are out of alignment?
    By LowriderS10 in forum Components, Wrenching
    Last Post: 09-06-2011, 11:11 AM
  5. How many have to adjust derailleur after swapping wheels?
    By sqwk77 in forum General Cycling Discussion
    Last Post: 04-19-2011, 10:51 AM
