Tire Pressure
Results 1 to 23 of 23
Thread: Tire Pressure
    Reputation: velodog's Avatar
    Sep 2007
    Tire Pressure
    Interesting interview of Josh Poertner.
    Too old to ride plastic
    Reputation: davesupra's Avatar
    Jun 2017
    Interesting video, thx for posting.
    Liars often accuse you of lying. - Steve Maraboli
    The word of the week = racist.
    What the what???
    Jul 2009
    Is there a tl;dr summary?
    The Law of Headwinds states: If the ride out is easy you better leave something in the tank for the turn...
    Schuylkill Trail Bum
    Reputation: SPlKE's Avatar
    Sep 2007
    Quote Originally Posted by Opus51569 View Post
    Not really, but it's definitely worth the time if you're interested in things like rolling resistance, tire materials, pressure, vibration, etc.
    The guy's an engineer who started Silca. Engineers, in my experience, are not usually tl;dr-able when they're explaining stuff.
    What the what???
    Jul 2009
    Quote Originally Posted by SPlKE View Post
    Ah. Okay. I'll check it out in a bit. Thanks.
    Reputation: Oxtox's Avatar
    Aug 2006
    all I learned is that 140 psi is too high.
    already knew that...
    Apr 2003
    You're only off by about 100 years.
    Russian Troll Farmer
    Sep 2016
    ..... Engineers, in my experience, are not usually tl;dr-able when they're explaining stuff.
    Hey! I resemble that remark!
    "L'enfer, c'est les autres"
    Sep 2007
    Quote Originally Posted by asgelle View Post
    Opps. He's the owner and president. I thought he looked too young to have started such an old company.
    Feb 2002
    Yup. Many people ride with too much pressure because their tires "feel faster" when they are hard. High pressure results in faster tire wear, higher suspension losses, reduced traction, and less comfort. And with gravel riding, there is an argument that casings under higher stress (from higher pressures) cut more easily.
    This is the essence of the argument being made for the past decade or more by Jan Heine at Bicycle Quarterly (backed up by extensive testing). It's only taken the bike industry a decade to catch on.
    δanned
    Reputation: SauronHimself's Avatar
    Nov 2012
    The obvious: Most people run tire pressure that is too high.
    The not so obvious:
    --If you can hear high frequency sounds as you cruise down the road, that is not synonymous with fast. Humans are terrible at gauging speed via sound, which is why we still get hit by trains (he literally says this in the video). Generally speaking, the quieter you roll the faster you're going.
    --To find ideal pressure you should work your way down in small increments until you feel the most comfortable smoothness. If you start bobbing when pedaling, you've gone a few PSI too low.
    --Wider tires are still generally faster, but not all tires are made equally. Material (i.e. latex vs butyl) can have drastic consequences on efficiency.
    --Asphalt road which appear smooth aren't always smooth because of the "negative spaces" (gaps). They cause your tire's flat spot to deform as badly as protruding bumps.
    Ghurarmu shirkush’ agh azgushu. Zant ya apakurizak. Gűl-n’ anakhizak.
    Sep 2007
    Quote Originally Posted by SauronHimself View Post
    The not so obvious:
    Good tl;dr.
    Feb 2002
    I think you are talking about tubes, not tires. For tires, the thing that has the biggest effect is how supple the casing is, followed by rubber compounds and thickness.
    May 2012
    When the tech gets worked out, graphene doped tread on a synthetic/biotech sourced spider silk casing should make for incredible tires.
    Feb 2002
    Quote Originally Posted by Bremerradkurier View Post
    Personally I have my eye on PFM (Pure F#@$ing Magic TM) technology to take tires to the next level. Combine PFM with a solid grounding in Business Physics and you have a world beating situation.
    Oct 2017
    He also did an interview with Jan Heine that has very similar content. That video is also worth a watch...
    Sep 2007
    I used to be a high pressure tire guy.
    I've been running lightweight Vredesteins for the past 5 or so years. Love 'em to death, being a former longtime Conti GP 3000 through 4000 series aficionado/evangelist who got tired of flats and suboptimal cornering. (But hey, that's a subject for a whole 'nother "spirited" "debate" thread! My debate position... Resolved: Conti GP series are overrated, overpriced flat magnets, regardless of the top-notch rolling resistance specs and eternally glowing reviews. Bam!)
    Anyway, the Vreds I buy have manufacturer's recommended pressure something like 120-145 psi printed on the side.
    So I would typically run them at around 120 f / 130 r. 700x23.
    Now I run em at around 90 and all is well. I'm a heavy rider. When I'm particularly fat at the beginning of the season, I might run 90 f / 100 r, the extra lbs. to support the extra lbs. in my buttocks.
    The transition to lower pressure all started in threads here on RBR... primarily with cx yelling at people about running too much pressure... in addition to yelling at people for asking about tire pressure in the non-Wheels and Tires subforums.
    Now that I'm a convert to lower pressure, I'd gladly take the next step and go with a wider tire, but alas, my 1997 LeMond (which I still love and look forward to riding) hasn't got the clearance for anything wider than a 23.
    'brifter' is a lame word.
    You must spread some Reputation around before giving it to SPlKE again.
    I work for some bike racers
    and a bunch of skateboards
    Sep 2007
    I tried to help you out, but I couldn't neither.
    Sep 2007
    I've also been a fan of Vreds in 23's and 25's but been using Compass/Rene Herse since riding my 650b 42mm's. I like the Compass tires enough that when it comes time for tires for the other bikes I'm gonna try the Compass 700c 26mm. I'd like to compare them to the 25mm Vreds.
    Sorry to hear that your bike is restricted to 23's, luckily I can fit at least 25's on my other bikes.
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    Same here. Someone help us out, please!
    Reputation: upstateSC-rider's Avatar
    Aug 2004
    I got him for you guys.
    I was in a similar situation with an old Tarmac Pro frame I had, loved the fit but wanted a little more comfort. What I ended up doing was going to a tubeless 23mm with that old Stan's kit that included TL tires, valves, sealant, and rim tape to convert any rim to tubeless. I know some people don't like tubeless but it worked great for me in that situation.
    In reference to the Assault on Mt Mitchell...
    Quote Originally Posted by merckx56
    The easier solution is to find a biker bar in Spartanburg the night before, go in and pick a fight. The ass-whipping you'll get will be far less painful than the one Mitchell will give you the next day!
  1. Best tire pressure for 700C tire
    By MNdag in forum Wheels and Tires
    Last Post: 06-05-2014, 03:39 AM
  2. Tire pressure for Specialized Espoir Elite tire
    By Gregon2wheels in forum Wheels and Tires
    Last Post: 01-06-2014, 06:11 AM
  3. Tire pressure for Bontrager Jones cross tire
    By NextTime in forum Cyclocross
    Last Post: 10-17-2008, 09:32 AM
  4. Max Tire Pressure by tire size for Mavic Rims
    By merckxman in forum Wheels and Tires
    Last Post: 11-27-2006, 03:53 AM
  5. Best tire pressure/tire size for tar&chip roads
    By Thor in forum Wheels and Tires
    Last Post: 11-07-2005, 10:36 AM
