Tire Pressure Apps
Results 1 to 22 of 22
    Nov 2014
    Tire Pressure Apps
    Anyone have any real world experience with the tire pressure apps that are out there? Basically these calculators work with rider weight or rider plus bicycle weight, tire size and width, and weight distribution between front and rear wheels.
    Found there are several apps for IOS and Androde while there are calculator websites for Vittoria and Silca.
    MDM
    MDM is offline
    Jun 2020
    Quote Originally Posted by GKSki View Post
    There's an Excel spreadsheet out there that's based on the 15% tire drop criteria and testing that Frank Berto developed some years ago. That has worked pretty well for me for road and gravel bikes. My mountain bike pressures have been determined by trial and error.
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    A website, not an app, this one is pretty good, has been around for quite some time and uses the 15% drop method:
    Bicycle tire pressure calculator
    Enter your numbers in the 2nd box and use 45%/55% weight distribution. 40%/60 will give you too much difference between front and rear pressures.
    "With
    -- DCGriz, RBR.
    Apr 2003
    No app can tell you what the right tire pressure is for you. The depends on you, your bike, your tires, your roads, and your style of riding. They're all equally good at providing a starting point, but from there, you'll have to decide what's best for your individual priorities.
    Apr 2015
    The Vittoria app doesn't even allow for tire width. And it says at my weight I should run 130/135 psi on front/rear.
    What I do run is 60/80 psi on 28mm tires.
    I don't trust any app, other than taking the 15% drop method as a good starting suggestion. In fact it's what got me away from running hard-as-a-rock psi. My bike changed from a brick to a sports car.
    Banned Sock Puppet
    May 2014
    Quote Originally Posted by bobf View Post
    I agree that these are starting points and you need to tweak pressures to what works for you. The link I sent comes pretty close to what I use.
    130/135??? That doesn't sound right unless you weigh north of 300lbs.
    "With
    -- DCGriz, RBR.
    Feb 2002
    Quote Originally Posted by asgelle View Post
    This is it. For "narrow" tires, start with 90 psi (6.2 bar) front and 100 psi (6.9 bar) rear. It will be too high unless your tires are very narrow or you are quite heavy. Drop the pressure a few psi and see how you like it. You'll probably end up closer to 80/90. For "wide" tires start with 70/80 and go from there. Usually lower is better but if you are not a careful rider and just can't seem to avoid pinch flat situations, you'll be at the higher end.
    Whatever you do don't get sucked into the "feels faster" sensation you get from high pressures. The data do NOT support it. The "feels faster" mind set led us to 19 mm tires. Insanity.
    Apr 2015
    Agreed. You'll have to try the app. I weigh 190 (86kg), and I entered a total weight of 95kg for me and my bike.
    What the what???
    Jul 2009
    The calculator suggested 208psi. I'm no expert, but that seems a bit high to me...
    Given his penchant for nicknames, and his aversion to reading, I've decided to shorten Donald J. Trump to it's essence: Dump*
    I was "social distancing" before it was cool.
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    OMG that app is beyond horrible.
    There's not even an option for tire size. 130psi in a 23mm or a 28mm
    But what do ya expect. They can't even draw a bicycle correctly.
    Banned Sock Puppet
    May 2014
    ^This.^ A harsh ride will feel faster even though it isn't.
    "With
    -- DCGriz, RBR.
    Banned Sock Puppet
    May 2014
    Quote Originally Posted by Opus51569 View Post
    I think I know what's going on here. Your app must be weight per tire. Take 55% and 45% of that weight and you will get what you should have in each tire...........roughly.
    Again, this one is pretty good And again, use the 2nd box:
    I use 75 front/90 rear in my 28mm tires. I could use less, but I'm lazy and only pump up once a week.
    "With
    -- DCGriz, RBR.
    MDM
    MDM is offline
    Jun 2020
    What do you think about the Silca tire pressure calculator? I think it's based on a survey of what the pros use. The front tire pressure seems too high. I could also care less about what pressure the pros use.
    tlg
    tlg is offline
    May 2011
    Quote Originally Posted by MDM View Post
    It's a complete turd. One of the worst. Recommends 20psi over what I run.
    The Silca Professional Pressure Calculator
    Silca has spent the past few years amassing what is considered by most to be the largest collection of data in the world of tire size, pressure, rider weight, and course. From this data, the team at Silca has developed a tire pressure algorithm which fits more than 4000 optimal pressure data points from more than 100 athletes on more than 90 ProTour, Triathlon, CX and Gravel races worldwide.
    What a completely ridiculous method to amass data. Cyclists are notorious for doing things based on habit or history, not based on what works best. And of course, almost ALL pros are riding tubulars. I don't give a $#it what pressure pros run their tubular tires.
    MDM
    MDM is offline
    Jun 2020
    Agreed.
    I used the simple version where you only enter weight and tire width and it's exactly what I would use IF riding on really good road surface.
    I live in New England so in other words a tire pressure I only use once in a blue moon.
    I don't know what road surface the simple version assumes but if "very good" the calculation seems good to me. But it's 10-15 too high compared to what I almost always go with.
    Apr 2015
    more reasonable
    Just came across this web page with the "Zipp Tire Pressure Guide".
    https://axs.sram.com/tirepressureguide
    My results for front and rear (79/84 psi) are IMO too close together, but at least they are in the right ball park.
    I still like the 15% drop method with 60/40 weight distribution as the best starting point. YMMV.
    Reputation: upstateSC-rider's Avatar
    Aug 2004
    Maybe I'm too 'old school' but after a little bit of riding you know when a tire is inflated too much and feels harsh, and too little and squirms, no app needed. The right pressure is somewhere between the two, biased towards the harsh side if you're on pot-hole ridden roads like I am or on the softer side if you're on good roads or not in a paceline and have a good visual of any hazards.
    In reference to the Assault on Mt Mitchell...
    Quote Originally Posted by merckx56
    The easier solution is to find a biker bar in Spartanburg the night before, go in and pick a fight. The ass-whipping you'll get will be far less painful than the one Mitchell will give you the next day!
    Feb 2002
    Quote Originally Posted by upstateSC-rider View Post
    It's not "old school" to exercise simple common sense. Needing a tire pressure calculator is not far off needing an app to chose your socks.
    Schuylkill Trail Bum
    Reputation: SPlKE's Avatar
    Sep 2007
    I've been looking for one of those. Which app do you recommend for choosing socks?
    Banned Sock Puppet
    May 2014
    Quote Originally Posted by SPlKE View Post
    I've been looking for an app to find the best apps, but have yet to find one.
    "With
    -- DCGriz, RBR.
    Apr 2011
    After a little bit of using, you know when an app is too extreme and feels OCD, and too inadequate and feels ADD, no app for app choice needed. The right app is somewhere between the two, biased towards the extreme side if you're on spam ridden sites like I am or on the inadequate side if you're on not so popular sites.
  1. Best tire pressure for 700C tire
    By MNdag in forum Wheels and Tires
    Last Post: 06-05-2014, 03:39 AM
  2. Tire pressure for Specialized Espoir Elite tire
    By Gregon2wheels in forum Wheels and Tires
    Last Post: 01-06-2014, 06:11 AM
  3. Tire pressure for Bontrager Jones cross tire
    By NextTime in forum Cyclocross
    Last Post: 10-17-2008, 09:32 AM
  4. Max Tire Pressure by tire size for Mavic Rims
    By merckxman in forum Wheels and Tires
    Last Post: 11-27-2006, 03:53 AM
  5. Best tire pressure/tire size for tar&chip roads
    By Thor in forum Wheels and Tires
    Last Post: 11-07-2005, 10:36 AM
