Tire pressure for D2R2
Results 1 to 10 of 10
    Sep 2006
    I'm doing the 180k D2R2 this weekend and still playing with tire pressure. I weigh 190lbs and using Clement MSO 40mm (120tpi) tires. Been running them 75psi front and rear, which might be a tad high but worried about pinch flats Suggestions?
    Thanks
    Dec 2011
    I'd use 40 as a starting point and go from there. 75 on a 40mm tires is punitive.
    Sep 2009
    I know next to nothing about the D2R2 but I've put around 2500 miles on a set of Clement MSO 40mm tires. I ride mostly gravel mountain roads with a bit of stony double track.
    I weight 170-175 and on gravel/dirt roads I like the pressure to be around 45-50 lbs. I've never had a flat (pinch or otherwise) with those tires and there have been times when I neglected to check the pressure for a while and found them to be down in the 25-30 lb range.
    I'm using them on a Salsa Vaya and I consider myself a "light rider".
    hth
    'brifter' is f'ing stupid
    75?!? They must be hard as a rock. Don't inflate your tires so you won't pinch flat, they'll always be too hard. Inflate to a pressure that gives you the ride quality and traction you want for the 99.99% of the time you're not pinch flatting. On a 40mm tire you'd pretty much have to close your eyes and run into a lunar crater to pinch flat. I'd be running those at 40-45.
    #promechaniclife
    Granted I'm lighter than you but I've never known pinch-flatting to be an issue on gravel roads such as those at D2r2 and I ride them frequently with just regular 25mm road tires (Vit Pave, mostly). It generally takes a sharp edge like railroad tracks or the edge of a pot hole to cause a pinch flat.
    Than again, you do see a ton of people with flats on that ride so maybe I'm wrong but I'm under the impression that a lot of those flats are from sidewall cuts caused by sharp rocks. (bring a few boots by the way)
    I'm 50 pounds lighter than you and my only experience with 30mm tires is commuting so take it with a grain of salt but I'd mostly likely go 50 psi or so with 30mm tires for that ride and have 0 concern over pinch flatting.
    wheelbuilder
    Reputation: ergott's Avatar
    Feb 2006
    Oh, it's a thing. Happened to me a couple times which is why I prefer tubulars or a tubeless setup for those rides. The only clinchers I would bring back to a long gravel ride like that would be 42mm 650b. That's enough rubber to put pinch flats to bed. I've pinched Michelin Jets before when I only put 40psi in them.
    Quote Originally Posted by ergott View Post
    I've never had a pinch flat in thousands of miles on gravel with regular road tires but if others have been known to I'll stand corrected on saying pinch flatting isn't a big concern. Perhaps weighting 140ish does more to avoid pinch flats compared to many others than I give it credit for.
    wheelbuilder
    Feb 2006
    Um, heck yeah it does! I have ridden dirt ranging from 160-180lbs.
    You also know that not all gravel is created equal. Some of those roads have 2-3" rocks strewn about when freshly graded. Even a good rain will completely change the road surface (usually for the better). Washboard descents are notorious for pinch flat causing.
    Last year I rode Conti Cyclocross Speed tires(700 x 35) on the D2R2. I ran latex tubes with @45 psi with no flats. I'm only @150lbs fully loaded. I rode with someone for a while on a road bike with 25c gatorskins. That was impressive. Some of the gravel downhills would be sketchy for me on those, but he was a local.
    Reputation: kjdhawkhill's Avatar
    Jan 2011
    I start my spring rides at 50psi in a 35mm clement rear but @ 185-190lbs I've never had a pinch [fingers crossed] flat even running it as low as 38... I'd say start at 50 if you intentionally hit sharp curbs and holes... 47 is probably a better starting number for [our] weight.
    I don't have a specific gauge so I just use the pump mounted one. I've heard they aren't as accurate as a bike specific pressure gauge, but as long as I'm basing the pressure of the same pump, I don't worry about actual accuracy.
    The internet is a little like a bar, a wonderful place where we can bullsh(t our past, but it also, is full of reasonably reliable sources of information to be used as ammo to call "bullish)t."
  1. Tire recommendations for D2R2 ride
    By angelo1100 in forum Wheels and Tires
    Last Post: 04-20-2014, 05:13 AM
  2. Tire pressure for Specialized Espoir Elite tire
    By Gregon2wheels in forum Wheels and Tires
    Last Post: 01-06-2014, 06:11 AM
  3. Tire pressure for Bontrager Jones cross tire
    By NextTime in forum Cyclocross
    Last Post: 10-17-2008, 09:32 AM
  4. Max Tire Pressure by tire size for Mavic Rims
    By merckxman in forum Wheels and Tires
    Last Post: 11-27-2006, 03:53 AM
  5. Best tire pressure/tire size for tar&chip roads
    By Thor in forum Wheels and Tires
    Last Post: 11-07-2005, 10:36 AM
