tire theory including rotation
Results 1 to 6 of 6
    Nov 2006
    Front tire flatted after a ride; noticed a bunch of glass-like specs in the tire with two major cuts.
    I decided to replace the tire with a Bontrager AW2.
    Back tire was newer and in good shape with one small nick. I sealed the nick with super glue.
    Questions:
    1. Should I rotate the rear tire to the front and replace back with new or just replace the front with new? I was thinking about using the new on the back to protect it from road debris and sacrifice my older Rubino Pro tire but the new tire has Aero Wing technology and I would hate to waste the Aero-advantage in the back. How do you rotate?
    2. Do you see a bunch of micro-debris in your tires? What do you use to seal small nicks?
    3. Do you wait for thin tires or will you replace based on the amount of embedded debris/nicks?
    Thanks in advance,
    RoadCube
    Jun 2005
    Most people put the better tire up front on the theory that a rear flat is easier to ride to a stop than a front flat. I don't rotate, I just replace tires when they're worn down or start flatting too much. I don't bother sealing cuts with glue- if the casing is cut on the inside the tire goes into the trash, if it's not cut it's not a problem.
    Not a rocket surgeon.
    Reputation: tihsepa's Avatar
    Nov 2008
    The rear wears faster. Not because or weight but because of torque.
    You always want the best tire on the front.
    Replace the tires one at a time.
    New tire on the front.
    Front tire on the back.
    You can shoe goo nicks if it hakes you feel better.
    Replace when you get thread showing or too many flats.
    Have a nice day.
    Reputation: looigi's Avatar
    Nov 2010
    ^+1.
    IMO, gluing cuts does nothing except, as noted, perhaps make you feel better.
    In my experience, I flat no more frequently with well worn tires than with new ones. My theory is that new thick rubber may be slightly harder to get through but it holds sharp shards through many rotations and allows them to work through the tougher cords and belts over many rotations. Thin worn rubber is less likely to hold the objects.
    ... 'cuz that's how I roll.
    tlg
    tlg is online now
    Reputation: tlg's Avatar
    May 2011
    Quote Originally Posted by RoadCube View Post
    If you're going to glue nicks, don't use super glue. Super glue dies hard and rubber is flexible. The super glue won't hold. Use a rubber cement, preferably vulcanizing rubber cement.
    Reputation: matfam's Avatar
    Jul 2012
    Ditto what has already been stated. I inspect and dig out the big stuff. I do not rotate, after 3-4k I feel like I got my money's worth from both tires.
    People sleep peaceably at night because rough men and woman stand ready to do violence on their behalf. George Orwell
    Oregon Bike MS 2013 Team Matfam
  1. Tire rotation
    By TAC in forum Wheels and Tires
    Last Post: 09-06-2013, 06:42 AM
  2. Ahem...hem... herm...my theory is... that theory that is mine...
    By paredown in forum General Cycling Discussion
    Last Post: 06-21-2013, 09:55 AM
  3. Tire rotation question
    By tanner3155 in forum Wheels and Tires
    Last Post: 10-02-2010, 06:02 PM
  4. Tire Rotation. Do You Do It?
    By Christoph in forum Wheels and Tires
    Last Post: 11-05-2009, 06:09 PM
  5. Tire Rotation?
    By Roadweaver in forum Wheels and Tires
    Last Post: 10-04-2005, 09:19 PM
