Tire Width and Proper Inflation
Results 1 to 25 of 28
    Sswitzky
    Sep 2018
    Let’s say I have two tires, a 23mm with actual width around 25mm and a 25mm tire that measures true to stated size.
    Would you inflate both tires to the same psi? (assume both on front or both on rear).
    Cleavage Of The Tetons
    Reputation: rideit's Avatar
    Feb 2005
    What is the weight of a laden swallow?
    Oct 2017
    Quote Originally Posted by sswitzky View Post
    My answer is: "Probably"
    There is quite a bit of info missing before I can give a more specific answer
    Dec 2006
    Quote Originally Posted by rideit View Post
    Is it an African swallow?
    Russian Troll Farmer
    Sep 2016
    I have a non-scientific way of determining how hard to inflate your tires: On my bike, I found that with the classic 23mm wide tires, it worked best for me at 100 psi rear, 90 psi front, which was exactly 13 strokes of my floor pump on the rear, and 12 strokes of the pump on the front.
    Inflating my 42mm wide tires on my gravel/touring bike, I used the exact same number of strokes, and it was perfect, filling them at about 40 psi rear, 35 front. From that, I assume that the having same AMOUNT of compressed air is the key, which corresponds linearly with tire pressure.
    So, If you know how many strokes of the pump from completely flat works for you, use that on every tire width, then check your final pressure.
    "L'enfer, c'est les autres"
    Reputation: velodog's Avatar
    Sep 2007
    Have you communicated with the tire manufacturer yet? If they haven't put their, or their lawyers, recommendations on the side of the tires, they may be able to respond to an e-mail with the proper inflation guidelines.
    Too old to ride plastic
    No I wouldn't, I use about 10 PSI less for every 2mm I go up in tire size.
    While not a big deal when moving 2mm in either direction, try using 40mm tires with the same PSI you use on 23mm tires to get any idea if less psi for more mm's makes sense. If you don't blow the 40mm of the rim you'll see quickly that less PSI as tires get bigger makes a lot of sense.
    Sswitzky
    Sep 2018
    That’s why I am asking the question. Let me rephrase. If my tires labeled 23mm are really 25mm, should I inflate them as if they were really 25mm? In other words, a lower PSI?
    Sep 2007
    Experiment, the worse that can happen is a pinch flat.
    Nov 2002
    Sswitzky
    Sep 2018
    Thanks for the interesting article. My only follow up is what tires are considered “supple”? Are Vittoria Rubinos supple? Conti 5000’s?
    Nov 2002
    Yes, I would think so.
    Sep 2016
    How many tires put recommended pressures on them? This varies quite a bit due to rider weight, and even the type of layout. All I've ever seen is MAXIMUM pressure listed on the tire.
    You're not looking very hard then. I have three different brands (Vittoria, Challenge and Donnely) and they all have a range printed on the side. So a min and max.
    Sep 2007
    Hence lawyers.
    They also put a tire diameter on the side of the tire that isn't always grounded in reality. Like I said in another post, experiment. A cyclists weight, how\where ridden, tire type all come into play, and all of these things have as much to do, maybe more, in tire pressure as tire size.
    Like someone else here asked, "What is the weight of a laden swallow?".
    Apr 2013
    i would not, but inflation guidelines are done with a range. i tend to go toward the lower end of the band simply because of preference to ride quality
    Sep 2007
    I think, maybe, the real question of this thread boils down to...
    Is the tire size what is printed on the sidewall or a true measure of the tire diameter?
    I vote true measure=tire diameter\size.
    'brifter' is a lame word.
    It depends...on rim width for one thing. Are the 23 and the 25 on the same wheel? If yes I would go down 10 psi on the 25.
    This works.
    Quote Originally Posted by Finx View Post
    Exactly.
    And this
    And sometimes this
    ETA: I somehow missed the part about the tires actually being the same physical size despite being labeled differently. If they're the same size I'd use the same pressure.
    I work for some bike racers
    and a bunch of skateboards
    Apr 2015
    For starters, yes, but I'd do some experiments. What a formula says is only a place to start.
    BTW, I think the tire pressure calc. on the Vittoria web site is just silly. It doesn't even take width into account.
    Quote Originally Posted by bobf View Post
    Someone did a study where they used a device like what you'd use to measure durometer...they determined that to maintain the same surface tension, or 'feel' you'd have to reduce pressure by damn near exactly 10 psi for every tire size increase. I would assume this was using the same size rim.
    changingleaf
    Aug 2009
    I will also say probably.
    Feb 2006
    Since your two tires are effectively the same size (they have the same measured width), air them the same way. That's what I do.
    My 25mm GP4000S are 29mm on my very wide HED rims (20.5mm internal width, 25.5mm external width). So at 170 pounds, I use 65psi front, 80 psi rear. It's a fast, comfortable ride.
    I've gotten a few pinch flats at these pressures over the years. Each time, it was a sharp edged small rock that I hit at speed. No problems with bumpy railroad tracks or rounded potholes.
    Feb 2002
    Quote Originally Posted by rm -rf View Post
    This ^^^^^^^^^^^^^^^^^
    So you're saying if I wanted to use 35 psi in a 23mm tire and not pinch flat I couldn't just take a sharpie and cross out 23mm printed on the tire and and change it to say 40mm? (sarcasm)
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    Yes. Those two tires will have the same contact patch on the road and should therefore be inflated the same. The labeling is irrelevant.
  1. Rim Width - Tire Width Questions
    By littlepitboy in forum Wheels and Tires
    Last Post: 09-25-2014, 05:35 PM
  2. proper tire inflation
    By rivren5 in forum General Cycling Discussion
    Last Post: 04-18-2009, 05:30 PM
  3. Tire width vs. rim width
    By zpl in forum Commuting, Touring and Ride Reports
    Last Post: 08-19-2008, 07:22 AM
  4. Help: Tire width vs. frame/fork width question
    By TBone in forum Components, Wrenching
    Last Post: 08-07-2007, 11:51 PM
  5. Newbie Question: Tire Width vs. Rim width???
    By scotthunt1 in forum Cyclocross
    Last Post: 09-04-2005, 11:08 PM
