Which Tires
Results 1 to 5 of 5
Thread: Which Tires
    Which Tires
    I need to get some new tires, and I've been using the Vittoria Open Corsa CX for a long time. Both the new Corsa G+, and the Open Corsa CX are on sale at about half price. After reading several negative reviews on the G+, I'm leaning towards staying with the Open Corsa CX. Any thoughts would be appreciated
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    I will give you some thoughts, but keep in mind that I am conservative when it comes to tire choices.
    While I have been tempted by all the hype about the lofty, cushy, plush ride of the Corsa series tires, I have shied away as my take is that you don't get something for nothing. Looking around at reviews, the trade-off is puncture resistance, not to mention reports of delamination on tires that use the open tubular design vs. vulcanized tires in general.
    Right now, I am using Vittoria Rubino G+ tires and so far, I am very happy with them. No punctures or visible cuts in over 1500 miles. They are more comfortable than the Maxxis Re-Fuses I used before which are on the bombproof, but harsh end of the spectrum.
    If I were you, if you have had good luck with the Corsa CX's and are happy with them, I would replace with same. Although I believe the G+ is replacing the CX, I could be wrong. BTW, G+ stands for Graphine which is some "super, duper" compound Vittoria is boasting.
    "If someone needs 200 rolls of toilet paper for a 14-day quarantine, they probably should have made a doctor's appointment way before the COVID-19 outbreak." -- Unknown
    "With
    -- DCGriz, RBR.
    Hey there,
    Thanks for the info. Everything you said made sense!!
    Russian Troll Farmer
    Sep 2016
    Anything by Vittoria with the name "Corsa" on it is basically a bologna skin. Ride and handling will be superb, wear will be quick, puncture resistance nearly unknown.
    "L'enfer, c'est les autres"
    May 2012
    What do u think of the gp5000s? They're bound to become the new industry standard for $40 tires.
  1. tires, tires, tires
    By sparky821 in forum Commuting, Touring and Ride Reports
    Last Post: 01-22-2008, 03:39 PM
  2. NYC tires (urban tires)
    By npoak in forum Fixed/Single Speed
    Last Post: 03-09-2007, 08:01 AM
  3. Winter tires---Studded tires work in Wisconsin
    By ojf in forum Wheels and Tires
    Last Post: 12-04-2006, 09:32 AM
  4. Fast tires...slow tires
    By OJack in forum Wheels and Tires
    Last Post: 06-01-2005, 12:11 PM
  5. Are 25mm tires slower than 23mm tires?
    By UCLA_MCDbio in forum Components, Wrenching
    Last Post: 08-21-2004, 05:56 AM
